Bar Oil
/ Bar Oil #41
I'll bring mine back to tsc.....
So you saying you dont know if the winter weight oil you bought there is 10w or 20w?
/ Bar Oil #43
The can said winter oil.
Ya I get that. But winter bar oils come in 10w and 20w.
I'd steer clear of 20w ones.
All season and summer oil is 30w.
Just use some diesel and all good though. Was in manuals too.
/ Bar Oil
So cleaned the bar and the oiling groove. It was plugged up pretty good. I also put a new edge on the chain and worked the rakers a bit. Filled it back up with the silver bottle bar oil. Also took my 445 out with the same oil. My conclusions are this...
1. My first cuts were at the base, which was close to a full 24" AND had been rotting from the inside out. I think this very moist, very fine dirt from the decay was really gumming up the bar oil.
2. The white oak is pretty hard stuff. I cut through an entire silver maple, about 18" at the base and about 30' long with the 445. Stayed sharp until I made 3 cuts into the white oak. I don't think the raker depth was set very good for a very hard wood.
3. The silver stihl oil did ok without thinning because it wasn't mixing with those fine particles from the rot. However, it does not seem to flow past the bar onto the replaceable tip.
I had a small sample of the DGP bar oil from the Paul Bunyan show. Buckin Billy Ray raves about it. I had just used a bit of it in my electric saw and liked it. Put the rest of it in the 562xp. I really liked it. Seemed to flow well even cold. I'm going to buy a gallon of it and try it.
/ Bar Oil #45
The can is not in my possession. Here's what there page says,,,, which is not much.
The CountyLine Winter Chainsaw Bar and Chain Oil lubricates the bar and chain for smooth cutting performance in low temperatures. Designed to inhibit rust, this winter chainsaw bar set is sure to hold up for long-lasting use. The chainsaw bar set also contains tackiness agents to prolong performance. It's great for extending the life of the chain and bar.
  • Chainsaw bar set reduces heat and friction for safe use
  • Formulated for use in major brands of equipment
  • Extends the life of the chain and bar
  • Chainsaw bar set inhibits rust for long-lasting use
  • Contains tackiness agents to prolong performance
  • Lubricates the bar and chain for smooth cutting performance in low temperatures
/ Bar Oil #46
I've never had issues with it before, even below freezing, but the stihl silver jug bar oil seems to be gumming up really bad before it even leaves the bar cover. It seems to make the oiling inconsistant and my tip is getting hot or there doesn't seem to be enough oil on the cutting edge of the chain. I know its not to tight. Anyone had issues with this before?
Bar oil is just a cheap single grade oil that does a very light job in a pretty low friction environment. Solve your problem and save money by using a much better automotive oil. For example a 10w-30 or 40. It has much better lubrication quality anyway.
/ Bar Oil #47
What I've found from cutting a ton of extremely dry, extremely dead standing ash is that you make more dust than you do chips. That wreaks havoc on your bar/chain/oiling no matter what temp it is outside. But 20deg is definitely cold enough to justify winter grade bar oil. Cut it with diesel if you're in a pinch. If you're making repetitious firewood type cuts, pause in between cuts and mildly rev the saw to get some oil to the bar/chain. But even that might not be enough
/ Bar Oil #48
Take care filing the rakers; I filed mine too much on my small Echo. The chain grabbed while sawing a large White Oak which broke the chain and flywheel key. After evaluation, I was lucky the crank didn't break too.
/ Bar Oil #49
There is no need to grease the front sprocket on a bar. I stopped greasing mine over 30 years ago and have yet to burn up a sprocket nose.
Good luck!
/ Bar Oil #50
If it does have a sprocket/wheel you should be greasing the wheel often with the special grease gun that came with the saw.
The general rule is to grease it everytime you use the saw or not at all. Intermittent greasing breaks the dirt barrier around the nose sprocket bearing allowing dirt intrusion. Some new bars come sealed from the factory. Stihl has been using sealed nose bars for years.
Case SV280B (A60462)
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
2020 DRAGON ESP...
