Bar Oil
/ Bar Oil #1
walhondingMF
2012 MF2400
I've never had issues with it before, even below freezing, but the stihl silver jug bar oil seems to be gumming up really bad before it even leaves the bar cover. It seems to make the oiling inconsistant and my tip is getting hot or there doesn't seem to be enough oil on the cutting edge of the chain. I know its not to tight. Anyone had issues with this before?
/ Bar Oil #2
Bar oil is meant to lubricate the chain sliding in the bar groove. The sticker the better IMO. If your bar does not have a nose Sprocket/wheel it will get hot if you don't give it a break once in a while.
If it does have a sprocket/wheel you should be greasing the wheel often with the special grease gun that came with the saw.
/ Bar Oil #3
I use County Line bar and chain. I can say I’ve never had that issue with this brand.
/ Bar Oil #4
Maybe they had a bad batch? I don't use the silver stuff but have had good luck with orange general oil and blue which we're are running now. Is that the universal temp oil?
/ Bar Oil #6
My first reaction is to pull the bar/chain and make sure the bar groove is clean, the oil ports and passages on the bar are clean/clear and the oil port area on the chainsaw are clean.
If it's still happening, try a fresh bottle of oil. Maybe the jug you're using got contaminated?
After that I would drain the oil, make sure the feed tube is clean and in good condition. Pop the bar and drum off and check the oil pump is getting oil.
We have a local Stihl/Husky dealer; I use whatever Stihl or Husky oil is on sale and never had issues, besides dirty bar groove or gummed up oil passages.
/ Bar Oil #7
How old is the saw your having the trouble with ?
Have you followed the advice posted previously in this thread ?
Besides following that advice when the oil tank on my chainsaw is nearly empty I flush it out with gasoline about once a year, I have never experienced any oiling issues. You do need to be careful to not allow dirt to get into the tank when you remove the cover, I usually use a paint brush to brush the dirt away before removing the cover.
/ Bar Oil
I think I will flush it tomorrow before I go cut again. I took it in the garage after cutting. Ran it and it cleaned up and threw plenty of oil after it through all the buildup out. It just gummed up with so much junk so fast it was very abnormal for what has happened in the past.
/ Bar Oil #12
Yup, too much oil will cause sawdust buildup problems.
/ Bar Oil #13
Here stihl silver comes in light weight for winter and heavy for warmer weather. Could you be using silver heavy which is too heavy when it gets cold.
/ Bar Oil #14
The old way of cutting summer 30w bar oil is using diesel. Straight from owners manual.
or just buy winter weight bar oil 10w
Just buy the cheapest bar oil you can. Dont over pay for brand names.
/ Bar Oil
I will cut it and see what happens. I am paranoid about my bar and chain getting hot. The chain got dull pretty fast. Its about a 20-24" white oak so I know it can be hard on the chain also. Its far from any road dust so I am afraid the temp increase speed up the dulling of the chain.
/ Bar Oil #16
I've been using Great Value soybean oil. Get it in the gallon jugs at WalMart for very cheap vs the very expensive Stihl Eco Bar Lube which is exactly soybean oil. Haven't had any problems yet.
/ Bar Oil #17
Are you using Summer Weight oil ?
/ Bar Oil #18
I asked the guy I hire to remove trees around my buildings what bar oil he uses. He said the oil he drains from his truck and has for years. And he has a big assortment of Stihl saws in his fancy truck including an MS500i. Just saying.
/ Bar Oil #19
I sometimes need to cut on cold days having temps in the single digits. If the saw sits for a bit the bar oil can thicken and not flow well until everything warms up again. Rather than let the chain more or less run dry I have experimented with Marvel Mystery Oil as chain oil. At the time it was what I had on hand. When cold the MMO moves well through the pump and gives full coverage on 20" bars and as high as 36". It also helps to clean out any gummyness in the pump. As a cold day alternative it seems to work well and there has been no noticable wear on the bar. During normal temps I stay with traditional bar oil but MMO may be a good alternative for rough days in the cold.
/ Bar Oil #20
Used motor oil is a well known carcinogen. Just saying, we'll not be using it.
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2016 International WorkStar 7500 (A64194)
2016 International...
2012 PUMA BUMPER PULL (A67714)
2012 PUMA BUMPER...
2011 MIDLAND  GOOSENECK SPOOL TRAILER (A68842)
2011 MIDLAND...
PORTA POTTY (A68842)
2017 Toyota Tacoma 4x4 Ext. Cab Pickup Truck (A66736)
2017 Toyota Tacoma...
