Anybody using a backhoe attachment on their CUT?
   / Anybody using a backhoe attachment on their CUT? #11
Sure you can do that. Yanmar used to make about 4 different models of subframe and 3pt PTO-driven backhoes for their 25 hp and under tractors. So did several other companies. Bradco still does. We had one...It was Yanmar model YBH600, and cost about $2500 back in 1985.
They aren't real popular and you could probably pick one up for under a grand today. There really isn't anything much to go wrong with them. Ours had a PTO pump and about a 8 gallon hydraulic tank with filter under your feet.
I used it for chores like you describe for about 15 years and did a ton of handy work.
It's almost a toy - but a toy that easily does the work of several grown men laboring with shovels and wheelbarrows.
Even these tiny hoes are rough and stressful on little tractors, and really throw the tractor around - but it sounds like you have the experience to avoid tearing up the machine. And if your tractor has automatic draft control BE SURE TO TURN THAT OFF! Draft Control can tear up a 3pt/subframe hoe and you with it. It almost happened to me.
But they are real handy. I replaced mine with a real TLB but if I hadn't I'd still have it. I've not seen a thumb for one. If I had mine back I'd at least put a mechanical thumb on it. No more power than it has, you wouldn't have to weld the thumb mount to the dipper stick, just use some old Chevy leaf spring U bolts ought to be enough.
rScotty
rScottyView attachment 773024
I didn't even know Yanmar made one of these. I would LOVE to find one, especially for a grand! I'm gonna have to start looking. It looks to be a little smaller than what I was thinking of but with a thumb it would really do most of what I want it to do. If I could find one of these that cheap then I will keep the Case, just in case. Pun intended. The small size might just be perfect if I keep the big machine. And I already have a Yanmar tiller so it would have company when the post hole digger or back blade is on the tractor.
Thanks,
Eric
   / Anybody using a backhoe attachment on their CUT? #13
I guess I should have been more clear about the backhoe. I would not use a 3 point mounted one and included the one in the link to show the approximate size I am thinking about. I am hoping someone is using one in that size range and can comment on how useful or not the thing is. I am certain that any backhoe must be a subframe mounted one. I am not averse to buying a 3 point mount one and converting it to subframe mount. In fact, I have been looking at used backhoes online to see what's available and even though some are 3 point I still am interested because it would get converted.
Eric
You stated that in the beginning, but sometimes things get lost over the course of the discussion. I believe that is similar in size to my Woods 750. It was one of my most used implements, second only to my logging winch. I've dug stumps, water lines, and buried animals with it. My previous BH was a lightweight CadPlans kit, about 10% less powerful than my Woods. With that, I was able to finesse stumps out that my loader wouldn't lift. I even used the Caddigger to dig a 6 foot deep hole and set a 30 foot utility pole... THAT was a challenge!
It was one of my most used implements, second only to my logging winch until I realized how easily I could break the housing on my tractor just transporting it between holes. There's quite a bit of twisting action because all of the weight is in back of the mounts. I plan to either get my old 8N running or buy a subframe so that I can use it on my Kubota again.
I looked into a CadPlans kit, at least I think it was CadPlans, some time ago, over a year ago. It could have been someone else though. There was a death and 3 different folks in my close family had strokes in the last year or so and all that stuff has been stressful and kinda messed my sense of time up. Anyway, I contacted them and the hoe kit I looked at would only swing 150 degrees (I think it was 150) and I really want 180 degrees. I say that having experience with a hoe that swings just slightly over 180 degrees and even that has been limiting sometimes. I contacted CadPlans and they said the swing limitation was because their kits don't need machining and 180 degrees would require machining. Did you like your CadPlans hoe? should I maybe consider one and then modify it for 180+ degrees swing? Bear in mind that I do own a machine shop, with all kinds of welders and a plasma cutter available any time 300 feet from my house. I really only lack a hydraulic press, but I know a guy who will let me use his.
Thanks,
Eric
   / Anybody using a backhoe attachment on their CUT? #15
What tractor is it on? And how big is the hoe? Does it compare in size to the one in the link? I will not be using a 3 point mount, I just included the link to get a size comparison.
Thanks,
Eric
Its an LS XR3135 and the backhoe is a bit bigger than the one in your link but it's not a monster or anything.
   / Anybody using a backhoe attachment on their CUT? #16
Thanks,
Eric
The Cad Kit has it's place but is pretty lightweight. It was way too easy for it to rip itself apart if I wasn't careful. You would be better off sticking with the plan you originally outlined; buying a manufactured unit and making modifications as needed. Since you know how to weld it wouldn't be a big deal to make a stationary or even a hydraulic thumb.
   / Anybody using a backhoe attachment on their CUT? #17
If you have back issues climbing in and out of the BH seat to get into the tractor seat every 3 feet will get old and stale real fast. Do yourself a favour and find a CUT/SCUT TLB that has a swivel seat.
I've owned an AG CUT with subframe BH and will never buy one again. AG tractors just aren't made to handle construction duty. Sub-frame BH's suck almost as much as 3PH BH.
Sell your Case 580 and buy an older used mini-x with a thumb. Thank me later.
   / Anybody using a backhoe attachment on their CUT? #18
I have a Mahindra 1626 with factory backhoe. The 1626b . I like it and have used it quite a bit. Buried 4 horses with it. Dug out multiple stumps, dug several trenches. I definitely wouldn't want one smaller. The thumb, I rarely use. If I had it to do over, I probably wouldn't have bought it. Especially for the price. Seems likes it's more in the way than anything.
   / Anybody using a backhoe attachment on their CUT? #19
Not for me! My Kubota BX25 came with a frame mounted BH, and I find it very useful. Bought a thumb for it, and also a ripper tooth. It detaches easily in the fall when I swap it out for my rear-mounted snowblower, and it is stored out of the eay on a dolly in the garage.
It also serves as ballast for lifting heavy stuff with my FEL. If I didn’t have it, I would have to install weights back there instead, which serve no other purpose.
   / Anybody using a backhoe attachment on their CUT? #20
I meant I wouldn't have bought the thumb again. I don't think it's worth anywhere near 500 for a manual thumb. It's gotten in my way a lot more then I've actually used it.
I love the backhoe itself which is frame mounted. I use it all the time. It's definitely worth what I paid for it. I have a 10" and 16" bucket. I don't think I need the ripper. Seems to rip through roots just fine. Installation and removal is pretty quick and easy. 5 minutes tops.
Display Case and Hutch Pieces with Glass Doors (A56860)
Display Case and...
2003 Big Tex 10PI...
Hydraulic Tilt Bucket Mini Skid Steer Attachment (A56860)
Hydraulic Tilt...
Dell Servers (A56860)
INOP Honda 3 Wheeler (A57453)
INOP Honda 3...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A56860)
2025 Kivel 48in...
