8B Backhoe On A 4200?
   / 8B Backhoe On A 4200?
Has anyone put their own teeth on their backhoe bucket? This is a crimp-on getup. Two of the teeth are worn to the nubs and the other one is almost new. I really hope I don't have to take the bucket to the dealer but I can't figure out any way to put the teeth on.
   / 8B Backhoe On A 4200? #102
I have fix a mini-ex bucket a few times for my wife's cousin...the crimp on teeth never stayed on for him so I put a new cutting edge on and pin-on teeth.
When I did replaced the crimped style, I heated the tooth and used a punch to crimp them. If you let the shank get worn...then all bets are off-it will not hold a new tooth.
   / 8B Backhoe On A 4200? #103
That's the better kind of teeth. Many hoes come with one piece bolt-on
cast teeth, which are not sharp at all.
I have used off-the-shelf tooth holders that take crimp-on teeth, and
my own shanks. In both cases, I weld the sides of the teeth to the
shank. More secure and not too hard to remove. More here:
http://www.tractorbynet.com/forums/build-yourself/120888-bucket-dentistry-better-teeth-b.html
I don't have a heat source. Are they weak enough to crimp with a ball joint press (a stronger c-frame clamp) and a two foot breaker bar? Or I can really just weld them without crimping? They don't break loose regularly when digging in the rocks?
   / 8B Backhoe On A 4200? #105
that's super nice work arrabil. With all the equipment you already have, you should just by you a used set of torches to heat with.
   / 8B Backhoe On A 4200? #106
You don't need super heat like a O/A torch...just propane may be enough. The C-frame might just work-I never treid mine but at least on the bucket I fixed up the teeth where probably to close to use it anyway.
Thanks doall. Yes, I should probably already own torches. They would have been handy more than once by now. But I hate bottles. I have nowhere to put them. Its the same reason I flux-core instead of mig weld.
Kenny, I measured up the ball joint press I have and there was nothing I could do to get it to fit on the middle tooth. Sigh.
I'm gonna buy the teeth today and see what I can figure out from them. I have no problem welding them if they'll stay on.
   / 8B Backhoe On A 4200? #108
I have replaced and welded on numerous crimp-on teeth for box blades.
Often the crimp is not adequate from the factory to keep from losing
teeth off the scarifier shanks.
Of course a good crimp will hold, but I have never had a welded on
tooth fall off.
   / 8B Backhoe On A 4200? #109
That's kinda what I figured...;)
   / 8B Backhoe On A 4200? #110
MAPP gas is supposed to be a bit hotter than propane is available at HD.
(4) 275/70/18 TIRES (A58374)
(4) 275/70/18...
3 HOLE FOOD WARMER (A58374)
3 HOLE FOOD WARMER...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58216)
2013 TEXAS PRIDE...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
(2) LP GAS TANKS (A58374)
(2) LP GAS TANKS...
