8B Backhoe On A 4200?
/ 8B Backhoe On A 4200?
Has anyone put their own teeth on their backhoe bucket? This is a crimp-on getup. Two of the teeth are worn to the nubs and the other one is almost new. I really hope I don't have to take the bucket to the dealer but I can't figure out any way to put the teeth on.
/ 8B Backhoe On A 4200? #102
I have fix a mini-ex bucket a few times for my wife's cousin...the crimp on teeth never stayed on for him so I put a new cutting edge on and pin-on teeth.
When I did replaced the crimped style, I heated the tooth and used a punch to crimp them. If you let the shank get worn...then all bets are off-it will not hold a new tooth.
/ 8B Backhoe On A 4200? #103
That's the better kind of teeth. Many hoes come with one piece bolt-on
cast teeth, which are not sharp at all.
I have used off-the-shelf tooth holders that take crimp-on teeth, and
my own shanks. In both cases, I weld the sides of the teeth to the
shank. More secure and not too hard to remove. More here:
http://www.tractorbynet.com/forums/build-yourself/120888-bucket-dentistry-better-teeth-b.html
I don't have a heat source. Are they weak enough to crimp with a ball joint press (a stronger c-frame clamp) and a two foot breaker bar? Or I can really just weld them without crimping? They don't break loose regularly when digging in the rocks?
/ 8B Backhoe On A 4200? #105
that's super nice work arrabil. With all the equipment you already have, you should just by you a used set of torches to heat with.
/ 8B Backhoe On A 4200? #106
You don't need super heat like a O/A torch...just propane may be enough. The C-frame might just work-I never treid mine but at least on the bucket I fixed up the teeth where probably to close to use it anyway.
Thanks doall. Yes, I should probably already own torches. They would have been handy more than once by now. But I hate bottles. I have nowhere to put them. Its the same reason I flux-core instead of mig weld.
Kenny, I measured up the ball joint press I have and there was nothing I could do to get it to fit on the middle tooth. Sigh.
I'm gonna buy the teeth today and see what I can figure out from them. I have no problem welding them if they'll stay on.
/ 8B Backhoe On A 4200? #108
I have replaced and welded on numerous crimp-on teeth for box blades.
Often the crimp is not adequate from the factory to keep from losing
teeth off the scarifier shanks.
Of course a good crimp will hold, but I have never had a welded on
tooth fall off.
/ 8B Backhoe On A 4200? #110
MAPP gas is supposed to be a bit hotter than propane is available at HD.
You guys see the exploding fireballs from Benzomatic MAPP and Propane cylinders when the tops break?
Thanks to avc8130 I finally have a mounting comparison between the stock 47 and my 8B. Looks like I might have done slightly better than Deere did. :D
/ 8B Backhoe On A 4200? #113
I think the turf tires larger diameter is creating an optical illusion. If you're adept with a decent paint program, you could cut and paste the turf tires onto the rig with the R4's to get a better comparison.
I was actually measuring from the center of the axle hub. See the new pic for what I mean.
How about this then.... my mounting isn't any worse than Deere's....
/ 8B Backhoe On A 4200? #115
I agree that the different diameter of the turfs vs. the R4s make it hard
to compare the mounts visually. Of course, the 47 is much different than
the 8B, too.
It DOES look like your departure angle is better for the 8.
/ 8B Backhoe On A 4200? #117
More of a rhetorical question cause there is soon going to be an 8B on my 4200. Picked it up Wednesday. And I removed all the brackets from the 970 tractor it came from too. The "leak" is from the fluid coming out of the connecting hoses. Too late to reposition them not to do that.
The 8B specs out in between the 47 and 48 weight and strength wise while utilizing the same hydraulic specs. This is unlike the 7 hoe which take less hydraulic pressure to operate and is much weaker than the equivalent digging depth 47.
I figure since the 42/43/4400 frame can handle the weight of the 48 hoe I can install a few hundred pound lighter hoe that still digs deeper than the 47 and costs a good bit less on the used market. And since I need to build a subframe for it anyway, I might as well have a hoe that came with half the subframe already there.
I'm probably gonna keep the brackets in case I need/want to sell the thing, but the plan is to copy the mounting design so that the hoe uses the same JDQA method as originally intended, and blend the design with dfkrug's subframe mount for his 4300.
You can also see how we pulled the UHaul trailer out from under the backhoe by strapping it to my offroader's bumper.
Hi Arrabil
I just picked up an 8B and looking to slide it under my 4410
Any tips from your project years back?
I have the underbelly subframe for the 8b but not sure if the other brackets are there. havent picked up yet.
Any thoughts would be appreciated.
p.s. Swapping the engine so will have some good parts from the old engine. Its spitting oil so wont know whats wrong till i split it apart but have a good engine i am gonna drop into it.
I figure you resolved your engine issue from 12 years ago but figured i would mention.
Any help appreciated.
Thanks
/ 8B Backhoe On A 4200? #118
Hi Arrabil
Thanks
Just an FYI, this thread is a decade old and the OP (arrabil) hasn't posted since 2013...
Too bad, nice guy...
/ 8B Backhoe On A 4200? #119
/ 8B Backhoe On A 4200? #120
Folks I have a JD 1070 and an 8B Backhoe. I need the attaching hardware, all 4 brackets and any other parts you may be willing to sell. I am in Nevada so finding parts here is a little tuff. If any of you know any one that would be willing to sell me brackets, please let me know. tom@looknupguides.com (530) 249-4979
John Deere 7000 Planter (A63109)
John Deere 7000...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
UNUSED SDLANCH 20' X 30' ALL-STEEL CARPORT (A62131)
UNUSED SDLANCH 20'...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2024 JCB 3TS-8TNA TELESKID (A62129)
2024 JCB 3TS-8TNA...
2008 Ford F-450 Flatbed Truck, VIN # 1FDXW47R68EA20949 (A61165)
2008 Ford F-450...
