Diamond Shape Sub-Frame for LW-8 Backhoe
   / Diamond Shape Sub-Frame for LW-8 Backhoe #21
but I hope I've written that clearly enough so as not to be confusing?
Thank you , yes you have . The valving you have is able to work in the x+ Axis and not just + which only allows for 90* movement . I wonder why they put the + in the tin panel so you can't use this function ?
   / Diamond Shape Sub-Frame for LW-8 Backhoe #22
Probally for saftey. So the user can only do exact movements. Liability. :mad:
   / Diamond Shape Sub-Frame for LW-8 Backhoe #23
This subframe is so rock solid that even the slightest movement of the backhoe is absorbed by the subframe. In other words, there is Zero play in it. And I mean absolutely ZERO play! And once the backhoe is up on it's stabilizer feet, it feels rock solid when digging.
Excellent. I know you were shooting for less play than with the Nardi's
subframe.
RE the LW-8 valves, I have heard a number of complaints. Compare/
contrast how they work with the Nardi valve: I heard they have no
load checks. Do they have any work port RV (shock-reliefs)? You have
already fixed the obvious limitation, the panel slots. If you can't
live with them, replacing the whole valve stack would not be too costly,
considering you got a great deal on the hoe.
   / Diamond Shape Sub-Frame for LW-8 Backhoe #24
Sounds like something Pelosi and crew would come up with to protect you from yourself.
Good job getting rid of that silly gated plate. Gated shift plates are cool on Ferrari's; but useless on a backhoe.
   / Diamond Shape Sub-Frame for LW-8 Backhoe #25
After that, I took the tractor out and started to dig a 60' long trench for the water and electrical lines for Loretta's garden shed. That's one of the projects we will be working on in the next few months.
Perfect timing... :D
[\quote]
Don't let him kid you... We were in the middle of the beginning of the garden shed project when he got the 'new' backhoe. He had already started to dig the trenches with the Nardi, but simply could not wait to get the new back hoe fixed up so he could try it out on something it could really get it's teeth into (pun totally intended).
So, now we can finally get back to the project.:licking:
(But I have to admit, this new hoe can really dig a cool ditch! He can even move the tractor with it, without getting out of his backhoe seat!!)
   / Diamond Shape Sub-Frame for LW-8 Backhoe #26
Now that you have the bigger hoe, when does the thread on your pond begin? LMAO
Eddie
Gee, I would have thought Robbie would have (hmm... is that too many 'would have's?) started a thread on it already.
Well, we actually started our pond last year around this time, but we had to stop when the ground got rock hard. We did so well with our dam, that it held water before we wanted it to, so we had to dig a trench in the dam so the storm water could get out... so we wouldn't be digging in the middle of water:laughing:
I'm sure we'll be dividing our time between the garden shed project and the pond project now... although my garden shed has higher priority (in my mind, at least:p)
   / Diamond Shape Sub-Frame for LW-8 Backhoe #27
Uh Oh, you're being tattled on Rob.:laughing:
Good to see you posting Loretta.:thumbsup:
   / Diamond Shape Sub-Frame for LW-8 Backhoe #28
Eddie
I was supprised he hadn't started a thread on it as well. I've been wondering how it was going. Thanks for the update. I assume that this means you'll see to it that we have something to read soon?:thumbsup::laughing:
Also, while we're on the subject of updates, how is the solar power system holding up now that you have some time on it?
Scott is possibly right in his reply?
Other than that, I don't know why. It works just fine when using simultaneous movements now.
Other than the valve is rather "rough" compared to the super smooth Italian Nardi backhoe valve. But nevertheless, I like the LW-8 and as you saw the trench, I'm getting used to it and it has a lot of power.
subframe.
The valve is the stock Jinma Backhoe valve (I believe).
It's not nearly as smooth or nice as the one on the Nardi. But since I made that change to allow all movements, I've gotten used to it. Need a little more time in the saddle, but I don't think I'll be changing out soon. I have not checked the valve out completely yet, so I don't know about the load checks yet. I plan on installing a pressure gauge on it soon though. I want to be sure the working psi is where it should be.
In fact, the Chinese hoe is like their tractors, lacking in fit and finish but the basic concept is good. The Nardi is a top quality hoe in comparison. And even though there is a lot more "flex" in the LW-8, it is still robust enough to do the job. When I swing the boom around, the dipper stick jiggles a little. The Nardi is solid. It also has a hydraulic filter (not suction strainer) and the LW-8 has nothing ... not even a suction strainer. It does have a lot of power though.
Another great project. I like the way you engineer stuff and explain why you do what you do. Nothing is random, and everything has a reason for why it was done that way!!!!
Eddie
Thanks Eddie,
Means a lot coming from you!
OMG, the pond ... Well, as soon as get my butt in gear and finish some of the many little projects around the ranch, Loretta and I will start when the ground gets a little softer. I knew that pond project would be a long term one. After following your thread for years, I knew it would be. Even though we've moved a lot of dirt already, it doesn't look like it. And there will be ten times more dirt to move yet!!:)
Hi Cyril,
Solar is doing a great job.
One evening last Winter we were looking out from our rear deck into the valley below. Usually there are little lights from the homes nestled around the river and up the mountain slopes. It was pitch dark ... no lights anywhere? We found out later that someone ran into a power pole and there was no electricity in the valley for 2 days. We had no idea...
And since you quoted Loretta's post, I too am hoping she will be the one to write that thread.
She's quite excited about the pond project and her garden shed as well. I'm sure I'll be contributing a little to the thread though.:)
   / Diamond Shape Sub-Frame for LW-8 Backhoe #34
Rob, quite drinking all that coffee and go get some more time on that hoe. :laughing:
   / Diamond Shape Sub-Frame for LW-8 Backhoe #35
Rob, good to see you and the Mrs. back posting again. Nice frame build. It looks rock solid like you've mentioned it is.:thumbsup: I don't remember how your Nardi attached but by the 3 point. Did you make something for it to mount other than the 3PH?
Oh! WWHHOOOOPPISHHHH!! (cracking whip sound) get back to those honey do's with those implements!:laughing::laughing:
Hey! At least they're honey do's you can use the equipment to do!:thumbsup:
Jay, Brian thanks guys.
I love coffee sooo much. hahaha
Gettin ready for a driving vacation for a week or so. I'll be back after the holidays to work again.
   / Diamond Shape Sub-Frame for LW-8 Backhoe #37
Rob, drive safe, be sure to take some tire chains, (you just never know) and have a good time.:thumbsup:
   / Diamond Shape Sub-Frame for LW-8 Backhoe #38
Very nice Rob. I am waiting for the return line filter mod to this BH... I am sure its on your short list.:thumbsup:
Chris
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A60432)
UNUSED FUTURE 24"...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
JCB 509-23TC TOOL CARRIER TELESCOPIC FORKLIFT (A60429)
JCB 509-23TC TOOL...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
Kubota L4701 (A53317)
