Another John Deere 1050 hydraulic problem.
/ Another John Deere 1050 hydraulic problem.
im sorry but i dont really understand the question sorry. but right now there is 4 lines that run to the fel and 3 that run back to the tractor
/ Another John Deere 1050 hydraulic problem. #43
Is the three point working via the lever beside the seat and not being affected by the loader controls
No the 3 point hitch is not working neither. I took my hydraulic pump apart to look at the seals to make sure I didn’t blow one. As I looked where the 2 gears are riding there is scarring around the walls. Could this be a reason why?
/ Another John Deere 1050 hydraulic problem. #45
Don't recall, but have you checked the hyd pressure yet? to know what psi you are getting and where you get it?
No I haven’t I don’t know what all is needed to do the test and where to do it. And what it needs to read. A guy I know that use to work for John Deere said it maybe the relieve valve I don’t even know where it’s located and how to tell if it’s bad. John deer quoted me 800 for a new pump. I think I’m going to be sick. I have so much invested in this tractor already.
CDED14F1-8F21-46C6-833B-E642A461FDE3.jpeg that’s what it looks like inside the pump housing
It’s just on one side 7B9839D0-4463-40A3-806A-79C4A1E291D5.jpegCEEC007F-7627-4295-B277-871632B611FA.jpeg3A6AD1A9-B934-4E73-BAB2-99B90C2F095A.jpeg
well back to square one the pump came in and installed still doing the same thing. hoses are routed right to the joystick control valve . I think something is wrong with the joystick control valve its self possibly letting fluid bypass. Its starting to get very frustrating almost to the point that i just want to take it john deere and let them fix it
can the 1050 be hooked up back like it was without a front end loader? does anyone have a pic on how it hooks up? if i hook it back up like if it didnt have a front end loader i can eliminate alot of things to have to check and it would narrow it down to the joystick control valve
Well thought I would update on this headache I’ve had on this tractor for a long time finally solved the problem 20666314-B6C0-4BF1-972E-F3C7048B53F9.png
/ Another John Deere 1050 hydraulic problem. #54
Thanks for that update. Hope all is working ok now. Been a tough row-to-hoe for you.
/ Another John Deere 1050 hydraulic problem. #55
Hi . I’ve read through this thread. I have the same tractor 1982 JD 1050.
I want to eliminate the old two stick auxiliary controls and replace it with a joystick.
Did anyone get this set up working?
/ Another John Deere 1050 hydraulic problem. #56
:welcome: to TBN
Which setup are you referring too?
/ Another John Deere 1050 hydraulic problem. #57
:welcome: to TBN
The set up I知 referring it is using the 7 port Cross joystick valve body.
I saw the pictures and write ups but I never saw if he got it working properly.
This setup was to control the FEL as well as supplying hydraulics to the three point hitch still
In the mix I have power steering as Well
/ Another John Deere 1050 hydraulic problem. #58
I’ve sent a pm to the gentleman who had the original questions on putting a joystick on his tractor.
Does anyone have any idea of the final results?
its works awesome now. i replied to your pm
2018 CATERPILLAR 420F2 BACKHOE (A59823)
2018 CATERPILLAR...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59905)
2018 INTERNATIONAL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
Sterling 9500 (A61306)
