Another John Deere 1050 hydraulic problem.
   / Another John Deere 1050 hydraulic problem.
can the 1050 be hooked up back like it was without a front end loader? does anyone have a pic on how it hooks up? if i hook it back up like if it didnt have a front end loader i can eliminate alot of things to have to check and it would narrow it down to the joystick control valve
   / Another John Deere 1050 hydraulic problem. #52
How goes the battle?
Well thought I would update on this headache I’ve had on this tractor for a long time finally solved the problem 20666314-B6C0-4BF1-972E-F3C7048B53F9.png
   / Another John Deere 1050 hydraulic problem. #54
Thanks for that update. Hope all is working ok now. Been a tough row-to-hoe for you.
   / Another John Deere 1050 hydraulic problem. #55
Hi . I’ve read through this thread. I have the same tractor 1982 JD 1050.
I want to eliminate the old two stick auxiliary controls and replace it with a joystick.
Did anyone get this set up working?
   / Another John Deere 1050 hydraulic problem. #56
:welcome: to TBN
Which setup are you referring too?
   / Another John Deere 1050 hydraulic problem. #57
:welcome: to TBN
The set up I知 referring it is using the 7 port Cross joystick valve body.
I saw the pictures and write ups but I never saw if he got it working properly.
This setup was to control the FEL as well as supplying hydraulics to the three point hitch still
In the mix I have power steering as Well
   / Another John Deere 1050 hydraulic problem. #58
I’ve sent a pm to the gentleman who had the original questions on putting a joystick on his tractor.
Does anyone have any idea of the final results?
its works awesome now. i replied to your pm
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV4NPNJ0430, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2008 Mercury Milan (A56859)
2008 Mercury Milan...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
Auger Drill Bit (A56857)
Auger Drill Bit...
