Another John Deere 1050 hydraulic problem.
   / Another John Deere 1050 hydraulic problem.
can the 1050 be hooked up back like it was without a front end loader? does anyone have a pic on how it hooks up? if i hook it back up like if it didnt have a front end loader i can eliminate alot of things to have to check and it would narrow it down to the joystick control valve
   / Another John Deere 1050 hydraulic problem. #52
How goes the battle?
Well thought I would update on this headache I’ve had on this tractor for a long time finally solved the problem 20666314-B6C0-4BF1-972E-F3C7048B53F9.png
   / Another John Deere 1050 hydraulic problem. #54
Thanks for that update. Hope all is working ok now. Been a tough row-to-hoe for you.
   / Another John Deere 1050 hydraulic problem. #55
Hi . I’ve read through this thread. I have the same tractor 1982 JD 1050.
I want to eliminate the old two stick auxiliary controls and replace it with a joystick.
Did anyone get this set up working?
   / Another John Deere 1050 hydraulic problem. #56
:welcome: to TBN
Which setup are you referring too?
   / Another John Deere 1050 hydraulic problem. #57
:welcome: to TBN
The set up I知 referring it is using the 7 port Cross joystick valve body.
I saw the pictures and write ups but I never saw if he got it working properly.
This setup was to control the FEL as well as supplying hydraulics to the three point hitch still
In the mix I have power steering as Well
   / Another John Deere 1050 hydraulic problem. #58
I’ve sent a pm to the gentleman who had the original questions on putting a joystick on his tractor.
Does anyone have any idea of the final results?
its works awesome now. i replied to your pm
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
HAY SPEAR W/ JOHN DEERE LOADER MOUNT (A58374)
HAY SPEAR W/ JOHN...
Rock/Skeleton bucket for skid steer / tractor (A56857)
Rock/Skeleton...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
1999 Eagle Road Tractor (A55272)
1999 Eagle Road...
