Another John Deere 1050 hydraulic problem.
   / Another John Deere 1050 hydraulic problem.
im sorry but i dont really understand the question sorry. but right now there is 4 lines that run to the fel and 3 that run back to the tractor
   / Another John Deere 1050 hydraulic problem. #42
Sounds correct
   / Another John Deere 1050 hydraulic problem. #43
Is the three point working via the lever beside the seat and not being affected by the loader controls
No the 3 point hitch is not working neither. I took my hydraulic pump apart to look at the seals to make sure I didn’t blow one. As I looked where the 2 gears are riding there is scarring around the walls. Could this be a reason why?
   / Another John Deere 1050 hydraulic problem. #45
Don't recall, but have you checked the hyd pressure yet? to know what psi you are getting and where you get it?
No I haven’t I don’t know what all is needed to do the test and where to do it. And what it needs to read. A guy I know that use to work for John Deere said it maybe the relieve valve I don’t even know where it’s located and how to tell if it’s bad. John deer quoted me 800 for a new pump. I think I’m going to be sick. I have so much invested in this tractor already.
CDED14F1-8F21-46C6-833B-E642A461FDE3.jpeg that’s what it looks like inside the pump housing
It’s just on one side 7B9839D0-4463-40A3-806A-79C4A1E291D5.jpegCEEC007F-7627-4295-B277-871632B611FA.jpeg3A6AD1A9-B934-4E73-BAB2-99B90C2F095A.jpeg
well back to square one the pump came in and installed still doing the same thing. hoses are routed right to the joystick control valve . I think something is wrong with the joystick control valve its self possibly letting fluid bypass. Its starting to get very frustrating almost to the point that i just want to take it john deere and let them fix it
403 (A52706)
403 (A52706)
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
LOT: (3) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (3) Kimball...
2013 FORD F-350 (INOPERABLE) (A58214)
2013 FORD F-350...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
