Another John Deere 1050 hydraulic problem.
/ Another John Deere 1050 hydraulic problem.
im sorry but i dont really understand the question sorry. but right now there is 4 lines that run to the fel and 3 that run back to the tractor
/ Another John Deere 1050 hydraulic problem. #43
Is the three point working via the lever beside the seat and not being affected by the loader controls
No the 3 point hitch is not working neither. I took my hydraulic pump apart to look at the seals to make sure I didn’t blow one. As I looked where the 2 gears are riding there is scarring around the walls. Could this be a reason why?
/ Another John Deere 1050 hydraulic problem. #45
Don't recall, but have you checked the hyd pressure yet? to know what psi you are getting and where you get it?
No I haven’t I don’t know what all is needed to do the test and where to do it. And what it needs to read. A guy I know that use to work for John Deere said it maybe the relieve valve I don’t even know where it’s located and how to tell if it’s bad. John deer quoted me 800 for a new pump. I think I’m going to be sick. I have so much invested in this tractor already.
CDED14F1-8F21-46C6-833B-E642A461FDE3.jpeg that’s what it looks like inside the pump housing
It’s just on one side 7B9839D0-4463-40A3-806A-79C4A1E291D5.jpegCEEC007F-7627-4295-B277-871632B611FA.jpeg3A6AD1A9-B934-4E73-BAB2-99B90C2F095A.jpeg
well back to square one the pump came in and installed still doing the same thing. hoses are routed right to the joystick control valve . I think something is wrong with the joystick control valve its self possibly letting fluid bypass. Its starting to get very frustrating almost to the point that i just want to take it john deere and let them fix it
can the 1050 be hooked up back like it was without a front end loader? does anyone have a pic on how it hooks up? if i hook it back up like if it didnt have a front end loader i can eliminate alot of things to have to check and it would narrow it down to the joystick control valve
Well thought I would update on this headache I’ve had on this tractor for a long time finally solved the problem 20666314-B6C0-4BF1-972E-F3C7048B53F9.png
/ Another John Deere 1050 hydraulic problem. #54
Thanks for that update. Hope all is working ok now. Been a tough row-to-hoe for you.
/ Another John Deere 1050 hydraulic problem. #55
Hi . I’ve read through this thread. I have the same tractor 1982 JD 1050.
I want to eliminate the old two stick auxiliary controls and replace it with a joystick.
Did anyone get this set up working?
/ Another John Deere 1050 hydraulic problem. #56
:welcome: to TBN
Which setup are you referring too?
/ Another John Deere 1050 hydraulic problem. #57
:welcome: to TBN
The set up I知 referring it is using the 7 port Cross joystick valve body.
I saw the pictures and write ups but I never saw if he got it working properly.
This setup was to control the FEL as well as supplying hydraulics to the three point hitch still
In the mix I have power steering as Well
/ Another John Deere 1050 hydraulic problem. #58
I’ve sent a pm to the gentleman who had the original questions on putting a joystick on his tractor.
Does anyone have any idea of the final results?
its works awesome now. i replied to your pm
2 Row cole planters (A64119)
2 Row cole...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2022 Braxton Creek Freesolo KITCH 18 ft Travel Trailer (A61574)
2022 Braxton Creek...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
