Adding grab hooks on front bucket, 2 or 3 hooks?
   / Adding grab hooks on front bucket, 2 or 3 hooks? #51
Pros or cons to adding the bolt on hooks?
I added bolt on hooks at the outside edges of the top and welded up a 2 inch receiver that bolts to the tractor frame for spotting a trailer or heavy pulls. The pull is more in line with the axles. Too easy to bend the top of the bucket with a center hook.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #52
I bought some bolt on hooks from Amazon. They come with reinforcing plates and bolts. I am currently deciding where to locate them on the tractor bucket.
https://www.amazon.com/dp/B09T5TYHKH?psc=1&ref=ppx_yo2ov_dt_b_product_details
   / Adding grab hooks on front bucket, 2 or 3 hooks? #53
   / Adding grab hooks on front bucket, 2 or 3 hooks? #55
It's easy to lift from the center with 2 side hooks if you have a hook on your chain. Think triangle with the chain end hook in the center.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #56
Yep. And the "load" on the hooks becomes a side load, rather than a straight pull in the direction of the hook load. No big deal if it's a light load.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #57
Yep, that's how I lift heavy loads if I only need one hook!
I'd written in an earlier post (on this thread) about pulling spilt rail fence posts...that's exactly how I rigged the chain...
   / Adding grab hooks on front bucket, 2 or 3 hooks? #58
It should not have to be a light load. If the hooks cant take an side load equal to what they can take straight on then they are substandard or improperly installed. Sorry but it's true and I'm not going to argue it.
I had my Terex 640 14 yrs using the hooks the same way, even lifting the rear off the ground many times against a chained load. Very heavy 14k pound tractor - no hook problems.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #59
No argument here. Simple physics. :)
   / Adding grab hooks on front bucket, 2 or 3 hooks? #60
USA made ones...Support small business and not Bezos and China:
I got your hooks man, I like them a lot. I also like that you engage here, share info and stuff, and contribute...as opposed to just being on here to sell your stuff. :)
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
