Adding grab hooks on front bucket, 2 or 3 hooks?
   / Adding grab hooks on front bucket, 2 or 3 hooks? #43
I did three on mine, as well. Two on ends are used with a 10' loop of 5/16" choker chain for lifting whole logs, or when my approach to something that needs to come from one side or the other. The one in the middle is used for pretty much everything else.
You could run a slack chain between the two side hooks, if you were lacking a middle hook, but it multiplies the side force on the side hooks, by the angle of your dangle.
Don't laugh at my welds, these were done blind with flux core, before I had my MIG set up with proper gas.
When I first started welding I told my uncle that I couldn't draw a very good bead and he said, "That's what they make angle grinder for." I'm a lot better now but still need the angle grinder on some of them.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #44
My Kubota B8200 had a hole and thick steel post with a threaded hole on each side of the top edge I found a grade 8 metric bolt the right length and put a hook on each side. This was a few years after I welded some 1/2 X 2 steel to the top edge of the bucket and welded a single hook in the center. I use the center one the most but am glad I have the two on the ends, too.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #45
get forks. They don't have hooks the bucket because the bucket isn't designed for loading on that area.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #47
Hooks aren't limited to something in the bucket...they're handy for lifting items, no matter the shape. Last time I used the hooks was to pull split rail fence posts out of the ground (2½-3 feet in the ground)
Forks are great for pallets and such, but not limited to pallets if one uses their brain...and buckets are not limited to carrying materials
   / Adding grab hooks on front bucket, 2 or 3 hooks? #48
Last time I used my bucket hooks I was carefully transporting 24' x 6 ft welded wire corral panels. Sometimes you just need to keep something relatively light in or on the bucket.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #49
It has been mentioned before but I don't like hooks in the middle, it seems it would be the ideal place for one, but it is the weakest part of the bucket. If you chose to put one in the center be sure you to but reinforcement on top or under the lip of the bucket. I have seen many loader with hooks in the center and the bucket lip is bent down, even heavy duty loader buckets.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #50
I have 3 grab hooks on my bucket.
1 on each end of the bucket and 1 in the center.
The center hook is by far the handiest, most used hook and I use it often
   / Adding grab hooks on front bucket, 2 or 3 hooks? #51
Pros or cons to adding the bolt on hooks?
I added bolt on hooks at the outside edges of the top and welded up a 2 inch receiver that bolts to the tractor frame for spotting a trailer or heavy pulls. The pull is more in line with the axles. Too easy to bend the top of the bucket with a center hook.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #52
I bought some bolt on hooks from Amazon. They come with reinforcing plates and bolts. I am currently deciding where to locate them on the tractor bucket.
https://www.amazon.com/dp/B09T5TYHKH?psc=1&ref=ppx_yo2ov_dt_b_product_details
   / Adding grab hooks on front bucket, 2 or 3 hooks? #53
   / Adding grab hooks on front bucket, 2 or 3 hooks? #55
It's easy to lift from the center with 2 side hooks if you have a hook on your chain. Think triangle with the chain end hook in the center.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #56
Yep. And the "load" on the hooks becomes a side load, rather than a straight pull in the direction of the hook load. No big deal if it's a light load.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #57
Yep, that's how I lift heavy loads if I only need one hook!
I'd written in an earlier post (on this thread) about pulling spilt rail fence posts...that's exactly how I rigged the chain...
   / Adding grab hooks on front bucket, 2 or 3 hooks? #58
It should not have to be a light load. If the hooks cant take an side load equal to what they can take straight on then they are substandard or improperly installed. Sorry but it's true and I'm not going to argue it.
I had my Terex 640 14 yrs using the hooks the same way, even lifting the rear off the ground many times against a chained load. Very heavy 14k pound tractor - no hook problems.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #59
No argument here. Simple physics. :)
   / Adding grab hooks on front bucket, 2 or 3 hooks? #60
USA made ones...Support small business and not Bezos and China:
I got your hooks man, I like them a lot. I also like that you engage here, share info and stuff, and contribute...as opposed to just being on here to sell your stuff. :)
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2022 BOBCAT T770 SKID STEER (A60429)
2022 BOBCAT T770...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
