A more robust Rodent Proofing solution? Is JD purposefully failing to address?
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #21
I've had old tractors I wrenched on regularly and new tractors I never wrench on... :unsure:
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #22
Me too, It's nice to have the choice between repairability and replaceability. Time vs Money.
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #23
I've read where mice can fit through a 1/4" opening. i park my tractor in an open field as rodents prefer brush cover close to where they nest. also keep my hood open as they shy away from daylight where they nest. good luck on that
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #24
Maybe a 1/4" size opening in one dimension, but not a 1/4" diameter hole, nor a 1/4" hardware cloth.
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #25
No mice around here anymore.
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #26
i had a rodent eat thru my plastic fuel tank. i ended up patching it and surrounded entire tank in 1/4" steel mesh. that was like 8-9 years ago. no more issue. rodents also got my wiring harness....some wheres. random fuse blowouts and repairs. the last straw was a constant short in starting circuit. i got a new harness from kioti for around $250 back 6-7 years ago and replaced it myself. did it in about 2 hours. no issues since.
you CANNOT stop rodents, but our bark cats are now allowed access to tractor and truck storage. issue resolved itself.
Crown Stand-On Electric Forklift (A59228)
Crown Stand-On...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
