A more robust Rodent Proofing solution? Is JD purposefully failing to address?
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #21
I've had old tractors I wrenched on regularly and new tractors I never wrench on... :unsure:
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #22
Me too, It's nice to have the choice between repairability and replaceability. Time vs Money.
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #23
I've read where mice can fit through a 1/4" opening. i park my tractor in an open field as rodents prefer brush cover close to where they nest. also keep my hood open as they shy away from daylight where they nest. good luck on that
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #24
Maybe a 1/4" size opening in one dimension, but not a 1/4" diameter hole, nor a 1/4" hardware cloth.
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #25
No mice around here anymore.
   / A more robust Rodent Proofing solution? Is JD purposefully failing to address? #26
i had a rodent eat thru my plastic fuel tank. i ended up patching it and surrounded entire tank in 1/4" steel mesh. that was like 8-9 years ago. no more issue. rodents also got my wiring harness....some wheres. random fuse blowouts and repairs. the last straw was a constant short in starting circuit. i got a new harness from kioti for around $250 back 6-7 years ago and replaced it myself. did it in about 2 hours. no issues since.
you CANNOT stop rodents, but our bark cats are now allowed access to tractor and truck storage. issue resolved itself.
2017 VOLVO VNL TANDEM AXLE DAY CAB (A58018)
2017 VOLVO VNL...
LOT: (1) Craftsman Shop Vac, (1) Dewalt Shop Vac (A59076)
LOT: (1) Craftsman...
2020 Caterpillar 299D3XE High Flow Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
1831 (A58374)
1831 (A58374)
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
