4410 electrical problem
/ 4410 electrical problem #1
meangreanmashean
Temple, Texas USA
JD 4410 ePowrReverser
My 4410 suddenly died while sitting at idle the other day. After some checking I found the f5 fuse had blown. タfter some more checking, I found that if I leave the mfwd switch plugged in, it will blow the fuse when the key switch is turned "on.". Leave it unplugged and fuse is good, but the tractor won't start. I even tried jumping the starter. Engine turns over, but won't start. IIt sounds like it's not getting any fuel. The fault code light flashes one long (3 secs), 6 short, 1 short. Any ideas?
Thanks,
Steve
/ 4410 electrical problem #2
Not sure what a mfwd switch is but if you have a fuse that keeps burning up it would have to be either a bad switch,bare wire,bad ground or something letting too many amps to that fuse.Time to start testing components and tracing wires
/ 4410 electrical problem #3
Put a 12v lightbulb in place of the fuse (rig with soldered wires to old fuse is what I do) and it will light up when there is a short. Lets you play with the wires to find the problem, without destroying more fuses.
More searching found there's no juice to fuel solenoid. I assume it's the relay. Can someone tell me the location of said relay?
Thanks,
Steve
Fuel solenoid checks out Ok after all. Seat switch was holding it out. Made switch, tractor started. Still had to jump across starter to do so but at least I know fuel solenoid is ok.
Hey beenthere I'll have to give it a try. It seems I'll be tracing wires.
Thanks,
Steve
/ 4410 electrical problem #6
Works great for me, and once helped me find a short in a wire that was above the headliner in my Chev Citation. New car and several trips to the dealer to no avail led me to chase it down on my own. Plug it in and started moving wires around until "poof" the light went out.. never would have imagined to look for a wire above the headliner that had a very small piece of insulation torn.
It is crude looking, but works.. here is a pic.
/ 4410 electrical problem #7
Sounds to me like the fuse F5 that you are blowing not only powers the MFWD switch but also the fuel solenoid.
With MFWD unhooked, and good fuse in, it should run. But plug in MFWD switch and fuse blows, thus loosing fuel solenoid that is also powered by that fuse.
The issue appears to be with the MFWD switch
/ 4410 electrical problem #8
see if this helps -
I have the Deere Tech manual with electrical schematics in a PDF if you'd like it. Shoot me your email if so -
Yours is a work of art compared to mine. :). I tried hooking it up and wiggling wires but so far Nada.
Thanks,
Steve
PM sent joecdeere. I'm sure I'll benefit greatly from that. I'm going to put the DMM to the mfwd switch to start with. Wish me luck!
Thanks,
Steve
Ok here's what I got. Unless I'm missing something the mfwd switch is OK. However the tractor will start when the mfwd switch is engaged. If it is disengaged turn the key and poof the fuse blows. :banghead::confused3:
I'm really lost now.
PS: With the bulb in place of the fuse, I've wiggled and pulled and I got nothing. Not even a flicker.
/ 4410 electrical problem #12
So the bulb doesn't come on when the mfwd switch is disengaged, and then turn the key on ?
Don't blow another fuse, just let the bulb take the place of the fuse while you check out what is happening.
/ 4410 electrical problem #13
Check the solenoid for MFWD. It may be energized to disengage MFWD.
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
136" BULLDOZER ROOT RAKE (A65056)
136" BULLDOZER...
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
1457 (A65054)
1457 (A65054)
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A67714)
PALLET OF 51 X 41...
Unused 2024 Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
