So do I need a 26 1/2" Inside clearance or 27 1/2" IC? I have A YM2310.
Either will fit the tractor. Measure your implements, then buy to match all (most?) of them.So do I need a 26 1/2" Inside clearance or 27 1/2" IC? I have A YM2310.
The largest advantage to me is I can leave the implements on rough (and sloping) ground where it would be difficult to rassle them into alignment by hand later. With the QH, just back up and use the force of the tractor to shove the implement around until it lines up.
... What holds the arms apart during that operation? I notice that when the implement was disconnected, the arms fell toward each other when the tractor pulled away.
