32x56x12 The Barn
/ 32x56x12 The Barn
/ 32x56x12 The Barn #165
Have you ever seen a ground and polished concrete floor? Similar to a large floor buffer but with grinding wheels of course to finer grits. The process actually hardens the surface and looks like marble when complete. Only a clear sealer needs to be applied. Saw it done in a large machine shop years ago for all the aisles between equipment.
/ 32x56x12 The Barn #166
Please excuse my ignorance..... What is the bottom row of bricks sitting on?? Thanks!!!!! Is gonna be awesome!!!!
I've been wondering that too. Usually it's a concrete footer that goes down below the frost line and is part of the slab. I'm real curious how they did this so the bricks wont move during winter and crack.
/ 32x56x12 The Barn #167
Yeah, that was why I asked. I didn't see a poured brick footing that's normally visible.
Maybe they drilled into the floor slab and pinned a brick footing?
No bashing here at all. Just very curious. :)
/ 32x56x12 The Barn
Sorry for not responding, iOS 10 does not let me text responses so I'm using talk to text. As for the brick, it is sitting on a 42 inch plus putting by 16 inches wide
/ 32x56x12 The Barn
Is that foil tape used to seal around the windows? Never seen it used for that before. What is the OSB for that's resting on the ground at the base of your walls?
The silver tape is from P EL LA.
/ 32x56x12 The Barn #171
Awesome. Guess it's just hard to see in the pictures.
/ 32x56x12 The Barn
yes there's footings there I promise. Send did wash on top of them with several rains. They did clear the sand before putting the brick on the footing
/ 32x56x12 The Barn
The first few pages shows the footings being dug and poured
/ 32x56x12 The Barn #174
You did well on the saw cut deaths which are typically 25% of the concrete thickness. Sealer product you used has a good reputation.
/ 32x56x12 The Barn #175
Yes, in going back over the pics again I can see it. Was sure something had to have been used. This type of construction is new to me. Thank you very much for patience. :)
/ 32x56x12 The Barn #180
It is very strange to me that your HOA makes you brick your equipment barn of all things! I've never lived anywhere fancy enough to have a HOA but I don't think I'd like it.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
X-Star 300 Gal Fuel Tank (A64127)
X-Star 300 Gal...
3pt 6 Row Planter w/Row Markers (A64127)
3pt 6 Row Planter...
3pt 5-Shank Subsoiler (A64127)
3pt 5-Shank...
John Deere 7300 (A64126)
John Deere 7300...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
