Bob Rooks
Elite Member
The way it's designed you can't.hi bob.. how do you get to the clutch and brake bands without open heart surgery
mine isnt putting much power into the left track , no ability to turn right . i will check to see if oil in the system. if i need to replace clutches do i require removing saddle bags and rear end . could you please give advice on steps to get into them and replace . with what seals etc id need.The way it's designed you can't.
ive got nothing , australia doesnt have much . any manual or information is appreciated . my email is rivermartin27@gmail.comYou need to get this far for the steering clutches. Do you have a parts manual?
have you left the saddle bags/ hydraulic tanks on .You need to get this far for the steering clutches. Do you have a parts manual?
i put it up on blocks , both tracks go forward and back . both tracks behave the same when pedals are pressed , just left track is weak in its torque as it turns.. what do you think it may be , at a guess...Yes, drop saddlebags unless you have a way to suspend them. Gaskets and seals are in the manuals along with part numbers.
There are no service manuals for these machines.
Do you have the manual (foot) clutch?
When you say the left track is weak, do you mean the machine struggles to make a right turn or something else?i put it up on blocks , both tracks go forward and back . both tracks behave the same when pedals are pressed , just left track is weak in its torque as it turns.. what do you think it may be , at a guess...
Ok, then you have the hydraulic shuttle clutch, with a F-N-R handle on the left saddlebag by the throttle.yep , the 2 pedals left and right , not a third.
yep , it struggle to the extent want turn rightWhen you say the left track is weak, do you mean the machine struggles to make a right turn or something else?
i will email u .yep , it struggle to the extent want turn right
That suggests that the left steering clutch and brake are out of adjustment and not releasing completely.yep , it struggle to the extent want turn right
bonus , i filled the brake compartment with brake cleaner , driving a bit and it freed up the clutches . we have power to the left side now.The way it's designed you can't.
Great news! Now it turns left and right?bonus , i filled the brake compartment with brake cleaner , driving a bit and it freed up the clutches . we have power to the left side now.
