30hp Chinese Bulldozer Parts
/ 30hp Chinese Bulldozer Parts #102
The way it's designed you can't.
mine isnt putting much power into the left track , no ability to turn right . i will check to see if oil in the system. if i need to replace clutches do i require removing saddle bags and rear end . could you please give advice on steps to get into them and replace . with what seals etc id need.
/ 30hp Chinese Bulldozer Parts #103
You need to get this far for the steering clutches. Do you have a parts manual?
/ 30hp Chinese Bulldozer Parts #104
I take it you're in Oz, you have an Eastwind brand. They did the best rebrand I've ever seen, but I think they went out of business. The only parts sources I know of are in the US.
/ 30hp Chinese Bulldozer Parts #107
Yes, drop saddlebags unless you have a way to suspend them. Gaskets and seals are in the manuals along with part numbers.
There are no service manuals for these machines.
Do you have the manual (foot) clutch?
/ 30hp Chinese Bulldozer Parts #108
yep , the 2 pedals left and right , not a third.
/ 30hp Chinese Bulldozer Parts #109
i put it up on blocks , both tracks go forward and back . both tracks behave the same when pedals are pressed , just left track is weak in its torque as it turns.. what do you think it may be , at a guess...
/ 30hp Chinese Bulldozer Parts #110
When you say the left track is weak, do you mean the machine struggles to make a right turn or something else?
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2023 Deere 325G (A60462)
2023 Deere 325G...
2019 PETERBILT PB520 GARBAGE/SANITATION TRUCK (A59823)
2019 PETERBILT...
2023 JOHN DEERE 317G SKID STEER (A62129)
2023 JOHN DEERE...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
