30hp Chinese Bulldozer Parts
/ 30hp Chinese Bulldozer Parts #102
The way it's designed you can't.
mine isnt putting much power into the left track , no ability to turn right . i will check to see if oil in the system. if i need to replace clutches do i require removing saddle bags and rear end . could you please give advice on steps to get into them and replace . with what seals etc id need.
/ 30hp Chinese Bulldozer Parts #103
You need to get this far for the steering clutches. Do you have a parts manual?
/ 30hp Chinese Bulldozer Parts #104
I take it you're in Oz, you have an Eastwind brand. They did the best rebrand I've ever seen, but I think they went out of business. The only parts sources I know of are in the US.
/ 30hp Chinese Bulldozer Parts #107
Yes, drop saddlebags unless you have a way to suspend them. Gaskets and seals are in the manuals along with part numbers.
There are no service manuals for these machines.
Do you have the manual (foot) clutch?
/ 30hp Chinese Bulldozer Parts #108
yep , the 2 pedals left and right , not a third.
/ 30hp Chinese Bulldozer Parts #109
i put it up on blocks , both tracks go forward and back . both tracks behave the same when pedals are pressed , just left track is weak in its torque as it turns.. what do you think it may be , at a guess...
/ 30hp Chinese Bulldozer Parts #110
When you say the left track is weak, do you mean the machine struggles to make a right turn or something else?
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
John Deere 7410 (A53317)
John Deere 7410...
(INOP) ELGIN PELICAN SERIES P SWEEPER (A59823)
(INOP) ELGIN...
2007 Ingersoll Rand G240 214kW 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2013 Ford E-150 Passenger Van (A59230)
2013 Ford E-150...
