30hp Chinese Bulldozer Parts
/ 30hp Chinese Bulldozer Parts #102
The way it's designed you can't.
mine isnt putting much power into the left track , no ability to turn right . i will check to see if oil in the system. if i need to replace clutches do i require removing saddle bags and rear end . could you please give advice on steps to get into them and replace . with what seals etc id need.
/ 30hp Chinese Bulldozer Parts #103
You need to get this far for the steering clutches. Do you have a parts manual?
/ 30hp Chinese Bulldozer Parts #104
I take it you're in Oz, you have an Eastwind brand. They did the best rebrand I've ever seen, but I think they went out of business. The only parts sources I know of are in the US.
/ 30hp Chinese Bulldozer Parts #107
Yes, drop saddlebags unless you have a way to suspend them. Gaskets and seals are in the manuals along with part numbers.
There are no service manuals for these machines.
Do you have the manual (foot) clutch?
/ 30hp Chinese Bulldozer Parts #108
yep , the 2 pedals left and right , not a third.
/ 30hp Chinese Bulldozer Parts #109
i put it up on blocks , both tracks go forward and back . both tracks behave the same when pedals are pressed , just left track is weak in its torque as it turns.. what do you think it may be , at a guess...
/ 30hp Chinese Bulldozer Parts #110
When you say the left track is weak, do you mean the machine struggles to make a right turn or something else?
1991 FRUEHAUF TRAILER OPERATION FUEL TRAILER (A60736)
1991 FRUEHAUF...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
Snap-On Southern Thunder Edition 24-drawer tool box (A61307)
Snap-On Southern...
MGY Shop Heater (A60463)
MGY Shop Heater...
207275 (A52708)
207275 (A52708)
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
