Bob Rooks
Elite Member
Had we access to that information earlier, it would have saved peoples time and head-scratching. Hope all is better now.
Hi folks. I just was given a DH326ST dozer that the right side track does not drive. I have determined that the axel is not broken and possibly the clutch was stuck or burned out. At this point I was able to free up the clutch and seems to be ok. I was given the machine dissembled down to the axle. I have no manual and have no clue what fluids should be in this machine. I filled hydro tanks with standard hydro fluid (ISO 46) and the gear box with gear oil 80-90wt. Got the machine running but don't have seat yet to try the drive train. Does anyone know where I can get any info/manual/parts for this unit. I know it is Chinese some where 2000 to 04 ish. only 100 hrs on unit.
Thanks Dan
Hey Bob,
I did get all the files you sent. Thank you very much. I am about to tackle the electrical issues and was wondering if you knew if the voltage regulator is supposed to be lit up red. It is not charging the battery right now. I cant tell if the alternator is working or not yet. I haven't had a lot of time on it yet. I did get It back in the shop to start on the electrical issues. I do not have the correct ignition key assembly in it currently. I did order a new one and a new voltage gauge as well today. Seeing as 95% of the wire are all blue...Im sure that the current key I am using is not correct. The manual says that the key will start the engine turning it to the left when its warm and normally to the right when it is cold stopping on the pre heater before starting.
Do you know if the alternator should put out 13-14v? It was currently giving me 12.3v. I have not disconnected the battery and tested yet. I will hopefully do that later this week or week end.
Dan
You need a parts manual, there are exploded views in it.I am working on a Guilin JLW-R2 because it steers great to the right and lazy to the left. I took the plug out on the left side clutch housing and oil came out. The right side was dry. I have the owners manual and it doesnt have any exploded views of the gear box and final drives. Does any one have any pics. Also in front of the gear box there the trans i assume. I put fluid into it and it always empty. No leaks visable . anyone experience this. Thanks
Do you own this tractor?I am working on a Guilin JLW-R2 because it steers great to the right and lazy to the left.
