2019 ford ranger review....
/ 2019 ford ranger review....
Weekend ranger pics. Its tranny is still surging while at 20 to 40 mph and holding a steady speed. Its jumping between gears.
/ 2019 ford ranger review.... #1,102
I have the same complaint about my 2022 Toyota 4Runner. For example, if I'm coming into a town where the speed limit is 35 mpg and I back off the throttle it instantly downshifts. Then as I'm trying to maintain that 35 mph through town the tach jumps up and down a few hundred rpm the whole time I'm driving through town. Once I'm back out on the open road and driving 50+ mph the problem goes away. I believe it has something to do with the way they've programmed the computer that controls the transmission.
This surging is a more recent thing, like in the last 30K of mileage and a known problem with the 2019 rangers. Dealership has worked on it twice.
/ 2019 ford ranger review.... #1,104
Those 10 speed transmissions have had their share of teething pains.
/ 2019 ford ranger review.... #1,105
Sounds like the DPFE, if my reading is correct...
I made another appointment with the ford dealership about its tranny. If they can't fix it, I might go to the aftermarket transmission shop that's near us and quite good.
Sat at the ford shop yesterday for nearly 3 hours and they eventually said they had found a fail code in the tranny and a temp sensor was not working. Part was on order.
/ 2019 ford ranger review.... #1,109
Engine light cam on on my 2019 Ranger. It was not flashing everything seems to work OK, drove it home, any ideas?
/ 2019 ford ranger review.... #1,111
Pull the codes. Most parts stores will do it for free, but don't make the mistake of listening to their diagnosis or buy parts. Just write them down and head to the interwebs to research
/ 2019 ford ranger review.... #1,113
Check engine light includes a billion things. no idea
Thanks I'll take it to the mechanic Monday, I'm thinking something with an emissions sensor since it is running fine and engine light is not blinking.
/ 2019 ford ranger review.... #1,114
Simple code readers are down to about $12-15 dollars, and they are worth having around.
So, did you just fill up with has? The Ford EZ fuel "gate" sometimes will set it off, especially if you fill all the way up, and top off.
/ 2019 ford ranger review.... #1,115
^^Correct, don't do that. (y)
/ 2019 ford ranger review.... #1,116
I did just fill up yesterday and It does have the fuel "gate".
/ 2019 ford ranger review.... #1,117
The cause of the engine light was the coolant thermostat went bad triggering a malfunction in the emissions control. All fixed ready to go again.
2017 Nissan Altima 4 door (A61306)
2017 Nissan Altima...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2018 FREIGHTLINER...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
