2019 ford ranger review....
   / 2019 ford ranger review.... #1,111
Pull the codes. Most parts stores will do it for free, but don't make the mistake of listening to their diagnosis or buy parts. Just write them down and head to the interwebs to research
   / 2019 ford ranger review.... #1,112
VW check engine light.
   / 2019 ford ranger review.... #1,113
Check engine light includes a billion things. no idea
Thanks I'll take it to the mechanic Monday, I'm thinking something with an emissions sensor since it is running fine and engine light is not blinking.
   / 2019 ford ranger review.... #1,114
Engine light cam on on my 2019 Ranger. It was not flashing everything seems to work OK, drove it home, any ideas?
Simple code readers are down to about $12-15 dollars, and they are worth having around.
So, did you just fill up with has? The Ford EZ fuel "gate" sometimes will set it off, especially if you fill all the way up, and top off.
   / 2019 ford ranger review.... #1,115
^^Correct, don't do that. (y)
   / 2019 ford ranger review.... #1,116
I did just fill up yesterday and It does have the fuel "gate".
   / 2019 ford ranger review.... #1,117
The cause of the engine light was the coolant thermostat went bad triggering a malfunction in the emissions control. All fixed ready to go again.
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
WATER TRAILER (A58214)
2011 Big Tex 18' Trailer, VIN: 16VCX182XB2E04765, Tandem Axle, GVWR: 7,000 Lbs., Asset# 25 (A59076)
2011 Big Tex 18'...
2020 MACK P164T (A58214)
2020 MACK P164T...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
