Menu
Forums
Today's Posts
New posts
Search
Marketplace
Auctions
Database
Quick Review
Quick Owner-Page
Register
Log in
Join
What's new
Search
Search
Everywhere
Threads
This forum
Search titles only
Today's Posts
New posts
Search
Filters
Keywords:
Started by:
Last updated:
Any time
7 days
14 days
30 days
2 months
3 months
6 months
1 year
Hidden from guests
Sort by:
Sort order
Last message
First message
Title
Replies
Views
First message reaction score
Sort direction
Descending
Ascending
Menu
Log in
Join
Main
General Tractor Topics
You should upgrade or use an
alternative browser
Hydraulics
Discuss all issues relating to hydraulics in this forum.
Prev
1
Go to page
Go
52
53
54
55
56
Go to page
Go
273
Next
First
Prev
54 of 273
Go to page
Go
Next
Last
Filters
Show only:
Loading…
Filters
Open Center vs Closed Center
Oiltech
Dec 29, 2020
2
Replies
24
Views
8K
Jan 1, 2021
the old grind
M
Need help with snowplow balde cylinders
mooch
Dec 10, 2020
Replies
11
Views
2K
Jan 1, 2021
LD1
P
Loader Boom Drops Before Lifting
pittstate08
Dec 22, 2020
Replies
10
Views
13K
Jan 1, 2021
LD1
H
Hydraulic leak problem JD 300 Industrial
hamp34
Jun 27, 2017
Replies
18
Views
24K
Jan 1, 2021
wormmy4life
W
B
John Deere 401C Hydro trouble
Bid1
Aug 10, 2013
3
4
5
Replies
97
Views
49K
Dec 26, 2020
Tx Jim
Remote add on kit to FEL valves
Steppenwolfe
Dec 19, 2020
Replies
6
Views
1K
Dec 25, 2020
old and tired
G
Kubota L3240 Hydraulic Detent Pressure
garjess
Dec 20, 2020
Replies
8
Views
2K
Dec 24, 2020
ptsg
F
Is bleeding necessary after replacing hose?
frogpond
Jun 28, 2020
Replies
13
Views
32K
Dec 22, 2020
sparc
V
Backhoe fell over and died.
vsumoski
Oct 9, 2020
2
3
4
Replies
75
Views
15K
Dec 22, 2020
sparc
G
Diverter valve regeneration question
garjess
Jul 25, 2020
Replies
6
Views
1K
Dec 21, 2020
old and tired
MX6000 Add on Remotes - Float Options?
BackRoad
Dec 2, 2020
2
Replies
24
Views
21K
Dec 21, 2020
BackRoad
M
connecting snowplow to bucket curl circuit
mechenginpa
Dec 15, 2020
Replies
14
Views
3K
Dec 21, 2020
LD1
S
Power Beyond on NH-25D?
Scott1963
Dec 20, 2020
Replies
2
Views
456
Dec 20, 2020
Scott1963
S
M
What happens to a hydraulic pump when running at a lower RPM than reccomened?
MacandTosh
Dec 19, 2020
Replies
5
Views
14K
Dec 20, 2020
90cummins
9
S
Using rear remotes for a grapple
StuartDK45SE
Dec 29, 2014
2
Replies
37
Views
23K
Dec 18, 2020
comancheflight
Replacing Shaft Seals on Log Splitter Control Valve
WranglerX
Dec 17, 2020
Replies
3
Views
1K
Dec 18, 2020
WranglerX
K
CASE 1130_Runs like a champ nothing else works
KYIHCASE1130
Dec 7, 2020
Replies
6
Views
3K
Dec 15, 2020
KYIHCASE1130
K
Can I Use a Double Acting Valve with a Singe Acting Cylinder?
Iplayfarmer
Dec 3, 2020
2
Replies
29
Views
10K
Dec 12, 2020
Iplayfarmer
T
App or spreadsheet for Implement: search by model and returns flow
TheLimbSawCompany
Dec 9, 2020
Replies
4
Views
688
Dec 12, 2020
rademamj1
M
Massey 5435 3pt Lift Issue
mabkab6224
Apr 26, 2014
Replies
1
Views
1K
Dec 11, 2020
Dieselrod1
D
Terratrac GT30 Next Question: Reservoir Size?
Iplayfarmer
Dec 7, 2020
Replies
5
Views
681
Dec 7, 2020
ptsg
H
GPM/PSI for Cessna hydraulic pump # 245600?
handytravis
Dec 5, 2020
Replies
9
Views
3K
Dec 7, 2020
handytravis
H
Series Circuit Loader Valve
kimtexn
Dec 3, 2020
Replies
7
Views
3K
Dec 5, 2020
kimtexn
A
1959 Ford Powermaster 851
antbobeau
Dec 3, 2020
Replies
1
Views
502
Dec 3, 2020
John0829
J
F
Skid Steer Wheel turns forward when lever is moved backwards!
finchm
Nov 29, 2020
Replies
4
Views
5K
Nov 30, 2020
oldnslo
O
J
mail-order made-up hydraulic hoses
Jframe
Nov 12, 2020
Replies
15
Views
4K
Nov 30, 2020
Oldpath05
O
The holy grail coupler!
Aquamoose
Nov 21, 2020
Replies
8
Views
2K
Nov 30, 2020
Zebrafive
Just Discovered that Pump Out and Power Beyond hoses to Loader Reversed at Block ???
Gordon Gould
Nov 27, 2020
Replies
17
Views
6K
Nov 29, 2020
Gordon Gould
Hydraulic Pump GPM Question
kimtexn
Nov 26, 2020
Replies
17
Views
3K
Nov 29, 2020
wdchyd
B
Cross Reference not as simple to find............
bswiv
Nov 28, 2020
Replies
6
Views
1K
Nov 28, 2020
bswiv
B
C
JD 3320 Rockshaft control valve issue
case580
Jan 20, 2017
Replies
6
Views
19K
Nov 27, 2020
mikeeg02
M
S
Bobcat 873
Snowies
Oct 7, 2020
Replies
3
Views
10K
Nov 26, 2020
Snowies
S
W
Slip over Bellows for hydraulic cylinders
Willyscott
Nov 26, 2020
Replies
3
Views
926
Nov 26, 2020
repete
R
T
Tuff Torq KHS Drives
TimberXX
Nov 25, 2020
Replies
0
Views
606
Nov 25, 2020
TimberXX
T
K
Best place for troubleshooting hydraulics?
karltinsly
Nov 24, 2020
Replies
9
Views
1K
Nov 24, 2020
Industrial Toys
B
B7800 Rear hydraulics
Bill Hoffman
May 23, 2009
Replies
12
Views
10K
Nov 24, 2020
jonsstihl
J
M
New Diverter installed. Grapple won't open
mainenate
Nov 21, 2020
Replies
9
Views
4K
Nov 23, 2020
TMGT
Rear remotes- Kioti DK45-HST
Mark Headley
Nov 21, 2020
Replies
3
Views
3K
Nov 22, 2020
grsthegreat
L
Dump trailer conversion to gas engine/hyd pump.
lennyzx11
Nov 21, 2020
Replies
8
Views
14K
Nov 22, 2020
lennyzx11
L
QUICKE 310 Loader
Semper Paratus
May 6, 2020
Replies
7
Views
8K
Nov 20, 2020
Sawyer Rob
R
New Holland TC30 hydraulics are driving me nuts
racer86y
Nov 14, 2020
Replies
16
Views
13K
Nov 20, 2020
the old grind
B
FEL Bucket Strength Reduced (New Holland TC29DA with 14LA)
bartonkj
Nov 7, 2020
Replies
6
Views
3K
Nov 20, 2020
LD1
M
Adding Remotes to a Kubota L3240 - semi-home-brew style
mainenate
Nov 10, 2020
Replies
9
Views
7K
Nov 20, 2020
LD1
B
OPEN OR CLOSED HYDRAULIC SYSTEM
belah
Apr 26, 2014
Replies
6
Views
14K
Nov 19, 2020
K5lwq
S
Hydraulic quick connect repair
scottmarsc
Nov 19, 2020
Replies
1
Views
864
Nov 19, 2020
oldnslo
O
C
Hydraulic Couplers difficult to connect
claitner
Nov 18, 2020
Replies
6
Views
8K
Nov 19, 2020
oosik
M
Advertising in the threads. Template sent. moved to mm
Magister Hydraulics
Nov 18, 2020
Replies
3
Views
493
Nov 18, 2020
Magister Hydraulics
M
F
Towable manlift
fabricator01
Nov 13, 2020
Replies
10
Views
1K
Nov 17, 2020
Industrial Toys
D
Adding a subplate to a 12v power pack?
davedj1
Nov 16, 2020
Replies
5
Views
840
Nov 16, 2020
JPRambo
How I added rear remote hydraulics to my tractor
Piston
Jan 23, 2012
2
3
4
Replies
69
Views
250K
Nov 16, 2020
JDAOWNER
J
Prev
1
Go to page
Go
52
53
54
55
56
Go to page
Go
273
Next
First
Prev
54 of 273
Go to page
Go
Next
Last
You must log in or register to post here.
Main
