Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,322
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
My B2710 has a 3-spool rear hydraulics valve. I would like to use the middle valve to run a grapple-like device. Hows the ergonomics of using a rear right hand to operate a grapple?
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=408705"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=408704"/>
Thanks james, I'm inclined to do it just to get going, and then add forward controls later if it becomes non-joyous. Most of what I need is to be able to drive into a pile of brush clamp down on it and go to the burn pile without losing half of my load.
Thanks so much for the link on how to do it. The seat pan removal was the biggest PIA. The detents ball removal was very easy and I have them in a zip lock bag should I ever need them, although I highly doubt it. Used the grapple extensively yesterday and boy what a difference in production when you're not worried about getting stuck in the detent position.
I would absolutely get a diverter valve so that you can get a 3rd function on the loader curl with a push button on the joystick. If you place it on the loader arm after the original 4 QDs, it's very cost efficient.
/Marcus
A solenoid diverter valve switches between two circuits, and the curl lever controls the final output, and can be feathered.
A 3rd function valve uses a solenoid to operate a cyl at full flow. It is usually in the series flow path after the FEL valve.
If you have two remotes, you can do T-N-T .
JJ, A newbie question. What is T-N-T and what can you use it for. Trying to learn the acronyms. Thanks
So James K0UA - several years have passed. You still using this grapple method and how do you rate it. I'm giving some thought to it. Kioti now offers 3rd function and dealer said about $1,000 installed..
