Using rear remotes for a grapple
/ Using rear remotes for a grapple #1
StuartDK45SE
Angleton, Texas
Kioti DK45SE
Looking at a grapple in the near future for our Kioti DK45. I know adding a WR Long type kit is preferable, but if I wanted to run it off the rear remotes for now, how do you control the grapple? The tractor is new and so far we haven't run anything off the remotes. Does the lever that engages the remotes have more function than just that?
Thanks
/ Using rear remotes for a grapple #2
Thanks
It is how I control my grapple, by running hoses from the rear to the front. The DK series lends itself to this very nicely. I did extend the lever length so that I could keep my hand on the joystick and use my fingers to control the valve for the rear remote. It works very well.
http://www.tractorbynet.com/forums/...-quick-connects-loader-torque.html?highlight=
http://www.tractorbynet.com/forums/...ion-control-valve-lever.html?highlight=remote
installed 2.jpginstalled 1.jpgin use.jpgDSCF0555.JPGDSCF0550.JPGDSCF0527.JPGDSCF0528.JPGDSCF0514.JPGDSCF0512.JPG
/ Using rear remotes for a grapple #3
As for how to control it, this method gives much better control of the grapple pressure than a 3rd function button. It allows you to "feather" the pressure. Push the valve forward to open the lid, and pull it back to close the lid and apply as much or as little pressure as you desire.
/ Using rear remotes for a grapple #4
It all depends on how you want to control the grapple.
If you want instant full on flow, and a thumb switch for the control, then the 3rd function valve is for you.
12 VDC 10 GPM OC DA SOLENOID VALVE
1 STATION DO3 SUBPLATE OPEN CENTER
You can also do a diverter valve and use the FEL to control the grapple. About $100.
If you want to control the grapple slowly, then the lever remote should work for you..
The remotes can be used to control anything you have plugged in.
If you have two remotes, you can do T-N-T .
Thanks James and J.J. So James, does the remote lever move to the left and right once you move it forward? If I could get close to my log splitter, I could play with the lever, but the splitter is way back in the barn.
/ Using rear remotes for a grapple #6
:Your splitter should have a valve on it, and therefore, you would plug in to the remotes and bungee the lever to on and use the log slitter valve to control the log splitter.
Yes sir, the splitter has a valve. Just trying to figure out the remote lever on the tractor works. I thought it was either off or on. That's what got me to wondering how you would control the movement of the grapple with it.
/ Using rear remotes for a grapple #8
Your lever should be spring loaded to neutral. The more you move the lever away from neutral the greater the hydraulic flow. The more flow, the faster the cylinder will move. So you can control the speed by how far you move the lever.
Some valves will have a detent that the lever will stay in position when in detent. That is until the cylinder reaches system pressure then the lever will "kick" out of detent. With detent, you move the lever into detent, let go of it and (depending on direction moved) your grapple will open or close, and lever will kick out (grapple will remain open or grapple will remain closed). My valve has detent and that's how I use it.
Your valve could also have float. Usually in only one direction of the lever. If you push the lever too far the valve enters float. Not useful with a grapple. Sometimes I accidentally move the valve to float and the grapple stops moving. Just pull the lever out of float.
/ Using rear remotes for a grapple #9
It has infinite flow control in either forward or reverse directions of the valve. In other words you have control of the flow rate from just a little to maximum flow by how far you push the control either forward or backward. The flow will come out of the A and B connectors on the rear of the tractor in relation to which way the control lever is pushed. I still think there is something else you are asking but I can't seem to grasp it. When you say movement of a grapple, what do you mean?. I am talking about controlling the lid of the grapple and its closing rate with the rear remote.. As far as positioning the grapple that is controlled with your existing loader joystick.. A little confused here in Branson, as to what you are asking.:)
That answers it perfectly, sorry for the confusion. I just haven't been able to use it since it would be bad to do that without an implement hooked up.
/ Using rear remotes for a grapple #11
You can put a shunt hose (just a single hose that connects from one connection to the other) to practice using the lever. No matter how you move the lever it won't do anything at all, but it also will not damage anything.
/ Using rear remotes for a grapple #12
My Kioti DK45HST is also using rear remotes to power grapple. My problem is that the lever will not kick out of the detent position when the grapple reaches full open or full close position. How can I fix this as it appears to put added strain on the tractors hydraulic system when this occurs.
/ Using rear remotes for a grapple #13
...the lever will not kick out of the detent position...
I believe it's manual... you have to take it out of detent. I know log splitters have that feature but never heard of it on a tractor... (but I'm sure someone else will know of one!!!)
/ Using rear remotes for a grapple #14
Remove the detent balls. Before my tractor was delivered I ask for and the dealer suggested that they be removed. If you ever need continuous flow (like for a backhoe or wood splitter, that is why they make bungee cords.
Here is how to remove them.
http://www.tractorbynet.com/forums/.../228110-i-am-now-detent-less.html#post2617614
/ Using rear remotes for a grapple #15
Does your valve have a pressure setting for detent kick out release? An adjusting screw to set the kick out detent release pressure.
Some valves are made with non-adjustable kick out and others with adjustable kick out.
Do you know what kind you have?
/ Using rear remotes for a grapple #16
They don't kick out, they just burn the pump up. The best thing to do is remove the detent.
/ Using rear remotes for a grapple #17
I don't know if the valve has a pressure relief on it. I may pull the seat and look. If not I may try and remove the detent balls.
/ Using rear remotes for a grapple #18
Was your detent valve an option for factory parts or third party valve.
If it is, the manual should show if the detent pressure is adjustable.
The standard detent is a spring and little balls that drop in a groove.
/ Using rear remotes for a grapple #19
Ok I have removed the detent balls. The grapple works as it should. I think Kioti should come up with a better system for holding the valve open but when I do need to use the wood splitter or a backhoe a bungee cord will work just fine
/ Using rear remotes for a grapple #20
I agree, there needs to be some Exterior mechanical device that takes two hands to set to hold the lever in what would be the detent position. Think of a wedge hold open device that you push the lever forward with one hand and set the device with the other at the base of the lever. This way there could not be any way you could accidentally set it into detent, which is so easy to do with the stock setup.
Come to think of it, maybe I should design something, sell them and make a fortune. Because the stock setup has burned up a lot of pumps, from people accidentally pushing it forward into detent without realizing it.
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
Case CX75C (A62177)
Case CX75C (A62177)
New/Unused 3 Point Receiver Hitch Attachment with Gooseneck Ball (A65583)
