RX6620 - TH
- Joined
- Jan 1, 2026
- Messages
- 2
- Tractor
- Kioti 2023 - RX6620 - ROPS
First of all, thank you for any input you can provide.
I would like to add at least a second set of rear remotes to my Kioti RX6620. Potentially a third - although I think I could get by with just two. I will be installing a hydraulic top link and a hydraulic side link to make my use of box blade and blade more efficient. I imagine that a need for a third remote will be rare, if ever - so that is not my principal concern. And, if I ever need temporary access to either of the two proposed remotes (for use with a backhoe for example), I can go through the trouble of removing the top link temporarily thus freeing up a set of remotes.
I would like to accomplish this myself. My options from research are to go with either a 2nd remote kit made specifically for Kioti -- Kioti RX-Series w/ROPS 2nd Remote Kit -- or
Go with a more of a plug and play option from, for example, Summit -- Hydraulic Multiplier Kit, 3 Circuit Selector Valve Including Couplers and Switch Box Control
My question at this time is most directly: if I was to go with the 2nd remote kit made specifically for Kioti, I can see the install not being too difficult in so far as the installation of the of the assembly at the rear of the tractor and that of the control arm (and wiring), but will this installation also include me having to run a new set of hydraulic lines towards the front of the tractor? Or, alternatively, is the set-up that exists such that the 2nd set of remotes and assembly will simply utilize (piggy-back) the existing hydraulic lines that are already installed for the first set of remotes?
I have looked all throughout the sources I can find, and I can't find any installation instructions for the 2nd remote kit made for Kioti - of which I figure would answer my question if I could find them.
Thank you again for any help or advice you can provide.
