Racer86
You state replaced valves, etc. but I do not see any mention of doing any diagnostic work.
Have you installed a pressure gauge in the system as indicator of system pressure? This is one of the least expensive diagnostic tests you can perform.
I installed a gauge in the pressure port of my loader directional valve. This allows me to monitor pressure on all the functions.
If in pressure line I simply unplug the disconnect and operate that function to get my relief valve setting. This is now the baseline for checking other functions.
Example: if my baseline relief pressure is 2,500 PSI and then trying to raise an empty bucket my pressure is also 2,500 PSI I know that I have restriction some where in the lift circuit. If pressure is 1,000 PSI and loader barely moved there is a leak path somewhere.
My suggestion if you have not done so is get a gauge and do some diagnostic work.
