My UPS keeps screwing up
/ My UPS keeps screwing up #1
check
Elite Member
Dorset (cottage country) and Toronto, Ontario, Can
2009 Kubota BX25
Hello, I have a Schneider UPS That I bought last June and it has now taken to screwing up at in opportune times.
We had a power outage at the cottage when I was not there, and I could tell it was not working because I could not access my thermostat via the UPS. So, I had someone go in and check, and the UPS was screaming with a loud tone, which is unsure some sort of alarm, and of course, the wifi which was connected to it was not functioning.
There is a reset button on the front that my friend held down until the tone stopped, and then everything was functioning fine.
Now it is not working again, and there's no Power Outage, so that could not be the cause.
Any ideas?
Thanks,
James.
/ My UPS keeps screwing up #2
What's plugged into it, and how close to the UPS's rated load is it? A printer or something with a motor in it might have a larger start-up draw than the UPS is rated for.
/ My UPS keeps screwing up #7
Well, that is a bummer. I just bought this last June!
Got this from AI - they should replace the battery under warranty.
AI Overview
The APC (Schneider Electric) Back-UPS Pro BN1350M2 includes a 3-year manufacturer warranty for both parts and labor
. A battery failure in less than one year is considered premature, as these batteries typically last 3–5 years, and you are likely eligible for a free warranty replacement.
Micro Center
Micro Center +2
Action Steps for Replacement
  1. Locate Proof of Purchase: Find your receipt or order confirmation to establish the purchase date.
  2. Verify Warranty Status: Use the serial number (found on the bottom or back of the unit) with the APC Warranty Lookup Tool.
  3. Contact Support: Contact Schneider Electric/APC support to initiate a warranty claim.
    • Phone: (800) 800-4APC
    • Website: APC Contact Support
  4. Diagnostic Session: Be prepared for a diagnostic session, as support may require troubleshooting before approving a replacement.
    Schneider Electric
    Schneider Electric +3
Potential Causes for Early Failure
While a failure under one year is usually a defective battery, these factors can contribute to early degradation:
  • Improper Installation: The battery must be connected by the user before first use.
  • Environmental Factors: Excessive heat, dust, moisture, or poor ventilation can accelerate battery failure.
  • Overloading: Connecting too many devices (over 810W) can cause the unit to work harder and fail.
  • Deep Discharge: Frequent, long power outages that completely drain the battery can reduce its lifespan.
    YouTube
    YouTube +4
Replacement Information
  • Battery Part Number: APCRBC162
  • Warranty Replacements: Within the first 30 days, you receive a new unit; after that, you may receive a refurbished unit, though all replacements include a new battery.
/ My UPS keeps screwing up #8
battery is prolly dead, you need to to do a load test on it.
/ My UPS keeps screwing up #9
Thing about the batteries used in a UPS is age is their weakness, always check the manufacture date. I will not purchase one that is older than 6 months of age. They also do not like extreme temps, especially heat and need to be charged for at least 8 hours before being put into service, 12 to 24 is better. And yes, over loading can affect them but usually they will just shut down if they are.
/ My UPS keeps screwing up #10
lol why? UPS's that consumer use are line interactive, the battery isn't even involved.
/ My UPS keeps screwing up #11
I used to be the one to replace weak or dead UPS batteries in a data center. The batteries had nice, high-current Anderson connectors on them. I kept the connectors from the old batteries, just because. Now I've got a few spares . . .
/ My UPS keeps screwing up #14
Rode herd on a battalion of UPSs for many years. Agree with those that say battery needs to be replaced.
The big, refrigerator-sized, UPS in the data center had to have at least one battery module replaced every year.
/ My UPS keeps screwing up #15
A load test? Why not just a multimeter?
I've had batteries in my UPS units show ~12v but the output current was a few mA. They couldn't even light a 12v test bulb. The larger UPS units use a special 24v battery.
/ My UPS keeps screwing up #16
larger ups for consumers not commercial are the typical 12v SLA wired in series.
/ My UPS keeps screwing up #17
Yes, the old ones do. I have one of the old ones that uses two 12v batteries wired in series. I have four of the newer small versions (450-600VA) that still use the single SLA 12v batteries. The newer large (1000-1500VA) have batteries that come pre-joined and insert into the UPS like a cartridge. Expensive too at about $110. Third party batteries are available for about $56.
/ My UPS keeps screwing up #18
Battery dead. I have not had good luck with APC UPS's lasting long
/ My UPS keeps screwing up #19
/ My UPS keeps screwing up #20
I have APC and Cyberpower UPSs. I just replaced 196 batteries in an APC UPS. I have UPSs 5-20+ years old. I just stick new batteries in them. Almost always are good with new batteries.
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
Rhino 7.5ft Rotary Mower (A64127)
Rhino 7.5ft Rotary...
2009 Infiniti FX35 Multipurpose Vehicle (MPV), VIN # JNRAS18W09M158535 (A64557)
2009 Infiniti FX35...
