My UPS keeps screwing up
/ My UPS keeps screwing up #1
check
Elite Member
Dorset (cottage country) and Toronto, Ontario, Can
2009 Kubota BX25
Hello, I have a Schneider UPS That I bought last June and it has now taken to screwing up at in opportune times.
We had a power outage at the cottage when I was not there, and I could tell it was not working because I could not access my thermostat via the UPS. So, I had someone go in and check, and the UPS was screaming with a loud tone, which is unsure some sort of alarm, and of course, the wifi which was connected to it was not functioning.
There is a reset button on the front that my friend held down until the tone stopped, and then everything was functioning fine.
Now it is not working again, and there's no Power Outage, so that could not be the cause.
Any ideas?
Thanks,
James.
/ My UPS keeps screwing up #2
What's plugged into it, and how close to the UPS's rated load is it? A printer or something with a motor in it might have a larger start-up draw than the UPS is rated for.
/ My UPS keeps screwing up #5
When mine start screaming it is a sign the battery inside has failed. On average I get about 3 years per UPS and I have four of them.
/ My UPS keeps screwing up #7
Well, that is a bummer. I just bought this last June!
Got this from AI - they should replace the battery under warranty.
AI Overview
The APC (Schneider Electric) Back-UPS Pro BN1350M2 includes a 3-year manufacturer warranty for both parts and labor
. A battery failure in less than one year is considered premature, as these batteries typically last 3–5 years, and you are likely eligible for a free warranty replacement.
Micro Center
Micro Center +2
Action Steps for Replacement
  1. Locate Proof of Purchase: Find your receipt or order confirmation to establish the purchase date.
  2. Verify Warranty Status: Use the serial number (found on the bottom or back of the unit) with the APC Warranty Lookup Tool.
  3. Contact Support: Contact Schneider Electric/APC support to initiate a warranty claim.
    • Phone: (800) 800-4APC
    • Website: APC Contact Support
  4. Diagnostic Session: Be prepared for a diagnostic session, as support may require troubleshooting before approving a replacement.
    Schneider Electric
    Schneider Electric +3
Potential Causes for Early Failure
While a failure under one year is usually a defective battery, these factors can contribute to early degradation:
  • Improper Installation: The battery must be connected by the user before first use.
  • Environmental Factors: Excessive heat, dust, moisture, or poor ventilation can accelerate battery failure.
  • Overloading: Connecting too many devices (over 810W) can cause the unit to work harder and fail.
  • Deep Discharge: Frequent, long power outages that completely drain the battery can reduce its lifespan.
    YouTube
    YouTube +4
Replacement Information
  • Battery Part Number: APCRBC162
  • Warranty Replacements: Within the first 30 days, you receive a new unit; after that, you may receive a refurbished unit, though all replacements include a new battery.
/ My UPS keeps screwing up #8
battery is prolly dead, you need to to do a load test on it.
/ My UPS keeps screwing up #9
Thing about the batteries used in a UPS is age is their weakness, always check the manufacture date. I will not purchase one that is older than 6 months of age. They also do not like extreme temps, especially heat and need to be charged for at least 8 hours before being put into service, 12 to 24 is better. And yes, over loading can affect them but usually they will just shut down if they are.
/ My UPS keeps screwing up #10
lol why? UPS's that consumer use are line interactive, the battery isn't even involved.
/ My UPS keeps screwing up #11
I used to be the one to replace weak or dead UPS batteries in a data center. The batteries had nice, high-current Anderson connectors on them. I kept the connectors from the old batteries, just because. Now I've got a few spares . . .
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
Western 8.5 Pro Plus Ultra Mount (A62679)
Western 8.5 Pro...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
New Landhonor 78" Rock Bucket  (A62679)
New Landhonor 78"...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
