DIY bucket level indicator
/ DIY bucket level indicator #22
Got inspiration from this thread and built a prototype. Sorry for a bad picture.
So far works very well, no mater how high the forks are, it always show when they are parallel to the ground.
I'll give it a try for a while and see if it is useful i'll build something better.
I could see a bar attached to the bucket sticking up high with a pendulum hanging from it.
/ DIY bucket level indicator #23
I took a 2" wide piece of flat stock and bolted it to the side of the bucket exactly perpendicular to the straight edge of the bucket. No matter what level the loader is at, I can always easily see exactly how the bucket is tilted. Took all of maybe 5 mins and works great.
/ DIY bucket level indicator #24
My previous loader utilized a similar indicator, but it was a piece of flat stock parallel to the cutting edge. Current bucket has a good view of the flat top bucket, which makes it even easier to level. I don't ever use the official bucket level indicator.
As long as I can see the bucket, simpler wins.
/ DIY bucket level indicator #25
Curious as to how you see the angle accurately when looking at an angle from behind and not from the side.
/ DIY bucket level indicator #26
From where I sit, I do see it from the side. The bucket extends past my front wheels so I am viewing it at an angle from where I am seated.
/ DIY bucket level indicator #27
/ DIY bucket level indicator #28
That's what I mean... at an angle you get what's called cosine error.
I look at things like this in exaggeration.
Looking head on from behind you see no change as you tilt
Looking at 45 deg angle you see half of the tilt angle
Looking from the side you see the full tilt angle.
/ DIY bucket level indicator #29
I don't know, it works great and allows me to clearly see how the bucket is angled. I plowed a ton of snow using it a couple weeks ago and it really allowed me to get the angle right.
/ DIY bucket level indicator #30
My Yanmar has the bar that indicates a level bucket when the loader is on the ground. Works great.
But there is the other level... gravity level for when you are lifting something and you want to keep the bucket level.
I can see using one of those camper trailer level bubble gauges but seeing it is the issue.
Then I thought, well hell I can see the bucket once it's raised LOL
/ DIY bucket level indicator #31
The only time I need to know if bucket is level is if I am doing ground work and need to know where front edge (cutting) of loader is, so I think my rod and tube works quite well because I can not see frot edge of loader ... If I am "off" the ground level it is not usually a concern....
/ DIY bucket level indicator #32
"Level" in this thread means different things at times. Sometimes it means parallel to the ground. Other times it means 90 degrees to the pull of gravity.
Maybe the device should be called a "bucket position indicator" instead of "bucket level indicator."
Bruce
/ DIY bucket level indicator #35
The issue is, for bucket you need it to see if it it level only when it is on the ground, there are 100s options, but for the forks, there are 1000s of different positions. For me it is important easily to see if it is level in each of those, it is why i made it for the forks, bucket does not bother me in a bit.
/ DIY bucket level indicator #36
I use a portable wireless camera held with a magnet on the bucket, forks or FEL arms, or placed nearby off the tractor. I can then see the precise bucket / fork position on the screen in the cab. Once set up for a particular work operation, it works perfectly. The trick is to make sure the cameras are mounted out of harms way.
(INOP) KUHN 6 BASKET HAY TEDDER (A63290)
(INOP) KUHN 6...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
Bush Hog 2212 Mower (A64047)
Bush Hog 2212...
2011 Chevrolet Silverado 1500 Truck (A63116)
2011 Chevrolet...
30" X 144" STAINLESS STEEL TABLE (A63745)
30" X 144"...
2014 Timpte Hopper Bottom (A63118)
2014 Timpte Hopper...
