9 Worst Things You Can Do to a Diesel Engine
   / 9 Worst Things You Can Do to a Diesel Engine #21
These lists are always so pathetic.
How is fuel selection a "worst thing you can do to an engine" Efficiency and emmissions doesn't harm the engine in any way.
Sure, gasoline would be wrong, but that is NOT in consideration with selection. That extreme condition is akin to failing to refill the engine sump with oil after draining.
Like I said, these lists are pathetic!
   / 9 Worst Things You Can Do to a Diesel Engine #22
? please explain, can't follow your thoughts
   / 9 Worst Things You Can Do to a Diesel Engine #23
what's the current new vehicle 1st oil change since factory? 5-7k? can't imagine
It's 15,000 on Ram diesel pickups, I think.
But I should admit that my 3500, and several others of our vehicles, do not get the stipulated 6-month oil changes. Some often don't get changed until there's two years or more on the oil, which is still well below the allowed mileage.
My reasoning? There's no logical reason to do it based on time, and I have oil analysis results to prove my point. But, and this is important, when our vehicles get started they're driven until the oil is up to temp. Most of our drives are 75 miles or more...one way.
   / 9 Worst Things You Can Do to a Diesel Engine #24
what's the current new vehicle 1st oil change since factory? 4-6k? can't imagine
On my Cummins X15 engine in my semi-truck, 1st oil change is at 60,000 miles, and every 60,000 miles thereafter! By the time we sell them off at 4 years, 600,000 miles, they are using 1-2 gallons of oil in the last 60K, they hold 11 gallons ...
Not my truck, I just drive it ... but on my own stuff, I change at half what the manual calls for, and recommend changing front axle oil/fluid on MFWD tractors at a tenth of the recommended interval for the 1st change ... As they don't have a filter...
   / 9 Worst Things You Can Do to a Diesel Engine #25
incredible, guess i'm too old school. glad all mine are paid for & running smooth.
That sounds like something AI would come up with.
How would a diesel engine know or care if the fuel is red or not??
But I wouldn't mind seeing idling on the list.
I had the same thought re: AI... guess just a fact of life now.
re: dyed fuel they did say on / off road diesel not really talking about just the dye as now we have access to petroleum diesel, bio diesel in all different concentrations, and renewable diesel at the pumps.
I believe in the old days the dye only difference was true. Diesel was diesel and dye added whey taxes taken off. Today though not so much. Times have changed. So many different types of diesel out their to buy. (pure petroleum, B5 all the way up to B100, renewable, etc...) All very different. Each with their own ASTM manufacturing spec.
imagine 2 jerry cans of diesel side by side.
- one red / one clear. we can no longer say they are the same as one could be B100 and the other pure petroleum. Vastly different more than just the colour.
- or image 2 jerry cans of clear side by side. One B100 and one pure petroleum. Lots of differences more than just color as B100 is oxygenated and pure not.
Red B5 is vastly different than clear B100.
Red B100 is not the same as clear petroleum only.
Both are more different than just the dye
red vs non red diesel can be way different than just the dye.
So like you I don't think the engine would care about the dye but would care if red B100 was used when long term storage is planned VS clear renewable diesel which can be stored for years. So using the right type of diesel does become important.
Not so simple as it was in the old days.
So I can see why using the right type of diesel hits the list.
- A guy who puts on only 20hrs per year should not use B100 diesel, etc.. as B100 only stores for couple of months and attracts moisture way more than pure petroleum diesel.
- i won't use B20 in winter when it gets really cold as bio starts much harder and B100 has noticably less ability to make power. Bio diesel is oxygenated which makes for harder starting in winter and shorter shelf life, less power, etc... So sometimes in summer I will use Red B5-10 but in winter I will only use Red petroleum diesel. Color is the same but fuels vastly different.
Way to technical and confusing for this old soul. But red diesel can be vastly different from clear diesel AND red's can be vastly different as well.
cheers
I would disagree. But heck difference of opinions makes the world a much more interesting place.
A guy who only puts on 20 hrs per year but chooses oxygenated B100 diesel has made a very wrong choice I will would guess sure to have fuel related problems in his very near future.
A guy who blows snow and cuts wood at -30 like where I am from may l soon regret trying to start his diesel if using B100 unless almost everything else on the tractor in top notch shape.
So I think lists like these can offer some wisdom and make for good discussions.
   / 9 Worst Things You Can Do to a Diesel Engine #29
To me that has little to do with whether the diesel is red or not, but is instead about various kinds of diesel blends.
So again, take one specific blend. The engine won't know or care if there's dye in that blend or not.
   / 9 Worst Things You Can Do to a Diesel Engine #30
How do you know B5 from B100?
I never noticed on the pump where I buy my tractor fuel any "B" information.
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
1111-A (A54756)
1111-A (A54756)
Adams 6T Fertilizer Spreader (A56435)
Adams 6T...
2012 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2012 Vantage...
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
