Lift or mechanic's pit for new garage?
/ Lift or mechanic's pit for new garage? #61
As a kid one neighbor friend's Father made something interesting which was he used steel beams and poured concrete making ramps that went from ground level about 30+ feet long and up about 8 feet at the end where he had stops. It looked like it would hold a tank and it was very simple.
They used it all the time. It was outdoors near a shed.
/ Lift or mechanic's pit for new garage? #63
/ Lift or mechanic's pit for new garage? #64
My two cents: lift. A pit sounds tempting, but they don't work very well at all in the real world. Rarely will you need to lift up a tractor. Two or four post is your real decision. You'll need a 12' 6" ceiling minimum.
Mine:
/ Lift or mechanic's pit for new garage? #65
one annoyance to not be discounted with a two post lift is getting in and out of a vehicle... That post... :)
Not really an issue with asymmetrical post design.
/ Lift or mechanic's pit for new garage? #66
Depends on your vehicle, a 4 door sedan sits a lot differently then crew cab pickup with an 8 ft box.
/ Lift or mechanic's pit for new garage? #68
I highly recommend having at least two of these in your inventory. When I am pulling transmissions or differentials or anything that can potentially change the center of gravity when in the air I place one of these at either end of the vehicle.
/ Lift or mechanic's pit for new garage? #70
Beside the fall issue, pits need to be properly ventilated. Lethal gasses can collect in the pit as they are heavier that air.
/ Lift or mechanic's pit for new garage? #71
2 post if you want to do work on vehicle
4 post if you want to keep a vehicle off the ground and store stuff under it .
I've got a 2 post my buddies got a 4 post, any time he needs to do any type wheel suspension work well he up on my 2 post while his 4 post keeps his garage space open LOL
/ Lift or mechanic's pit for new garage? #72
After Daddy's Dodge was dropped from a 2 post lift "because it weighed so much more at one end" according to the dealership,
David from jax
That sounds like an excuse from an incompetent worker. I don't think I would trust that dealership very far if they don't even know the limitations of their own equipment.
/ Lift or mechanic's pit for new garage? #73
Can you put in a pit? I can't help but feel like I read a long while back those are frowned upon by some environmental government organization.
I don't remember why I'm thinking that, which is frustrating, but I would love a pit myself and someone once put a pin in that bubble.
I'm sure the pit and/or the lift, or whatever form you can think of, is frowned upon by some environmental government organization.
/ Lift or mechanic's pit for new garage? #74
I am planning out my garage for a new build. I plan on working on my cars, tractor and UTV in this garage. Which would be the best way to go? A lift, if that is even possible with a tractor considering how back heavy it is, or a mechanic's pit?
FYI. Tractor (Kioti DK6010SE + filled tires) is probably around 5,000 lbs but I may eventually upgrade to 100hp + tractor.
I'd suggest a lift unless you have the ability to have a walk-in pit--when you get older, climbing the ladder/steps to enter/exit the pit will be a pain. Also, the lifts provide much more versatility, whereas you would need to keep the pit covered or protected with some kind of barrier, such as railings.
/ Lift or mechanic's pit for new garage? #75
Before I relocated to warmed regions, I had a pit. Complete with air, power, and a ventilation system, which is critical. I miss it every day. If I could do it again next week, I'd go with a pit again. Design it carefully. Do not allow your wife to sweep the floor into it.
The ventilation system inside a pit is absolutely critical. My brother had one without one. Everything rusted when it was left in there. The lights and electrical, tire rims, etc... Once the electrical rusted out, it was super dark inside.
Plus, I found that when working in it the floor was never at the right/ideal height.
Hope those points help you make an informed decision.
/ Lift or mechanic's pit for new garage? #76
Once I get a vehicle about six inches off the ground I give it the shake test. ESPECIALLY trucks.
/ Lift or mechanic's pit for new garage? #77
Get a lift. BUT, don’t think a $1995 dollar 10,000lb chicom imported lift is the same as a $13,000 dollar 10,000lb American Mohawk lift - they aren’t! A fellow did a test where he filmed 10,000lb imported lifts failing to lift 7-8,000 pounds, and catastrophically failing. I bought used Mohawk lifts and they’re built like what they are - the best lifts you can buy. The 3/4” American steel they are made of is mighty impressive and reassuring. Try not to buy on price, but on the image of what you will look like after the bargain basement lift has failed and the vehicle has come down on your head.
/ Lift or mechanic's pit for new garage? #78
A 100hp+ tractor won't be lifted with a conventional car lift.
In a pit a car cannot fall on you, but you'll be climbing in and out for stuff. A pit also requires removal of pit cover before use, AND bad gasses can collect down there. The pit that i had used a vertical ladder to get out of it, saves space, but...
If you go with a pit, I'd recommend power and air be in the plan. Ventilation and light are a couple of the uses for power.
2 or 4 post lift?
/ Lift or mechanic's pit for new garage? #79
Yep. Mine is a 10k RotaryLift. Made in Indiana. Good rubber bumper on the drivers side post. The manual tells you where to put the front wheel location pad and where to park the vehicle according to the wheelbase. All require good concrete - mine is 6" thick where the posts are. I also had it installed. I could have drove an hour away, trailered it home, worked hard to get it in the shop, assembled and installed it, but the dealer brought it down from Minnesota and installed it for $750. No brainer.
/ Lift or mechanic's pit for new garage? #80
To me anyway, working height is very important. With a lift, It's much easier to adjust. I can set the height of the vehicle and sit on a stool while working, instead of standing on my feet, a ladder or a stool in a pit.
Cleanup is another issue. I know from experience how difficult it is to clean water and leaking fluids from the floor of a pit. Back in my teens & 20's, my friends and I would work on our hot rods at a neighborhood gas station where the owner used to let us use his pit. The deal was, we could use it but we had to clean it out before and after. The floor of the pit was below the water table so there was no drain. Water would seep in after a rain and we often had to bail it out with buckets. Our clothes were always filthy from rubbing on the greasy walls while we cleaned the pit and worked on our cars.
Still, there is the cost issue. Lifts are expensive and getting more so every year. They also require periodic maintenance. In some cases, a pit might be a cheaper option.
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2019 Mitsubishi Mirage G4 Sedan (A61569)
2019 Mitsubishi...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
New/Unused Landhonor Quick Attach Receiver Hitch (A61166)
New/Unused...
2015 Ford F-150 Ext. Cab Pickup Truck (A61568)
2015 Ford F-150...
