Lift or mechanic's pit for new garage?
   / Lift or mechanic's pit for new garage? #61
As a kid one neighbor friend's Father made something interesting which was he used steel beams and poured concrete making ramps that went from ground level about 30+ feet long and up about 8 feet at the end where he had stops. It looked like it would hold a tank and it was very simple.
They used it all the time. It was outdoors near a shed.
   / Lift or mechanic's pit for new garage? #63
   / Lift or mechanic's pit for new garage? #64
My two cents: lift. A pit sounds tempting, but they don't work very well at all in the real world. Rarely will you need to lift up a tractor. Two or four post is your real decision. You'll need a 12' 6" ceiling minimum.
Mine:
   / Lift or mechanic's pit for new garage? #65
one annoyance to not be discounted with a two post lift is getting in and out of a vehicle... That post... :)
Not really an issue with asymmetrical post design.
   / Lift or mechanic's pit for new garage? #66
Depends on your vehicle, a 4 door sedan sits a lot differently then crew cab pickup with an 8 ft box.
   / Lift or mechanic's pit for new garage? #68
I highly recommend having at least two of these in your inventory. When I am pulling transmissions or differentials or anything that can potentially change the center of gravity when in the air I place one of these at either end of the vehicle.
   / Lift or mechanic's pit for new garage? #70
Beside the fall issue, pits need to be properly ventilated. Lethal gasses can collect in the pit as they are heavier that air.
Husqvarna 46in Riding Mower (A56859)
Husqvarna 46in...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
John Deere 1025R (A53317)
John Deere 1025R...
