Lift or mechanic's pit for new garage?
   / Lift or mechanic's pit for new garage? #61
As a kid one neighbor friend's Father made something interesting which was he used steel beams and poured concrete making ramps that went from ground level about 30+ feet long and up about 8 feet at the end where he had stops. It looked like it would hold a tank and it was very simple.
They used it all the time. It was outdoors near a shed.
   / Lift or mechanic's pit for new garage? #63
   / Lift or mechanic's pit for new garage? #64
My two cents: lift. A pit sounds tempting, but they don't work very well at all in the real world. Rarely will you need to lift up a tractor. Two or four post is your real decision. You'll need a 12' 6" ceiling minimum.
Mine:
   / Lift or mechanic's pit for new garage? #65
one annoyance to not be discounted with a two post lift is getting in and out of a vehicle... That post... :)
Not really an issue with asymmetrical post design.
   / Lift or mechanic's pit for new garage? #66
Depends on your vehicle, a 4 door sedan sits a lot differently then crew cab pickup with an 8 ft box.
   / Lift or mechanic's pit for new garage? #68
I highly recommend having at least two of these in your inventory. When I am pulling transmissions or differentials or anything that can potentially change the center of gravity when in the air I place one of these at either end of the vehicle.
   / Lift or mechanic's pit for new garage? #70
Beside the fall issue, pits need to be properly ventilated. Lethal gasses can collect in the pit as they are heavier that air.
Turfco Mete-R-Matic XL Towable Golf Course Drop-Style Topdresser (A55973)
Turfco...
Electric Horseless Carriage (A57453)
Electric Horseless...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A56435)
2023 Kubota...
2006 JLG 450SJ SERIES II TELESCOPIC BOOM LIFT (A52709)
2006 JLG 450SJ...
2013 Peterbilt 367 T/A A-Frame Gin Pole Truck (A55973)
2013 Peterbilt 367...
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
