2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A56435)
Item Details
Auction ID
56435
Make
Kubota
Type
Year
2023
Auction House
Fastline Auction, LLC
Model
5660
Florida
Description: NEW 2023 Kubota M5660SUH Compact Utility Tractor with LA1154 Front Loader, 5 Hours. Open ROPS. 2WD. SAE Gross HP: 57.9. Engine Net HP: 56. Hydraulic Shuttle Transmission. R3 Turf Tires. 1 Set Rear SCVS. The Kubota M5660SU is a 56 hp utility tractor with an 8x8 hydraulic shuttle transmission, offering 50 PTO hp and a lift capacity of 3,307 lbs at 24 inches. It features a turbocharged 4-cylinder diesel engine, live-independent PTO, and a standard rear remote valve. The M5660SU is designed as a high-performing, value-oriented tractor for small to medium farms. Engine and power PTO Horsepower: 50 hp Engine Type: 4-cylinder, turbocharged, Common Rail System (CRS) direct injection diesel PTO: Live-independent hydraulic PTO, 540 rpm (540/540E rpm option available) Gross Engine HP: 56 hp Net Engine HP: 56 hp Transmission and driveline Transmission: 8 Forward x 8 Reverse hydraulic shuttle Drive: 2WD (2WD/4WD option available) Hydraulics Pump Flow Capacity: 11 gpm (40 lpm) Rear Remote Valves: 1 standard (more optional) Dimensions and operating specifications Operating Weight: 4,387 lbs (1,990 kg) 3-Point Hitch: Category I & II with telescopic lower link ends 3-Point Hitch Lift Capacity: 3,307 lbs (1,500 kg) at 24 inches behind the lift point Loader Lift Capacity: Up to 3,307 lbs (1,500 kg) at the pivot pin (with specific loader) Ground Clearance: 16 inches (42 cm) Key features Constant RPM management system, Telescopic 3-point hitch and stabilizers, Standard rear remote valve, and Tilt-up one-piece hood for easy maintenance. Year: 2023 Make: Kubota Model: M5660SUH Serial No.: KBUMFAFRCP8C10826 Hours: 5 Meter Reads: 5 Transmission: Hydrostatic Enclosed Cab: No Stock No.: E79207 FASTLINE SALES REPRESENTATIVE(s) Nick Herring nick.herring@fastline.com 919-922-2854 Item Location - Address: Provided by Seller Item Location - City: Bradenton Item Location - State/Province: Florida Item Location - Postal/Zip Code: 34212 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
see lot description, multiple locations, KY 40010
Starting Bid: 17500.00 USD
Auction Finishes: December 02, 2025 at 07:42 PM
Click Here To Bid Now!
Happy Bidding!
2020 CAT 308 (A53317)
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
