Anyone DIY dye their hydro oil?
/ Anyone DIY dye their hydro oil? #81
JD sells it, it's expensive per ml, you might get 2 fills out of it but they suggest it's for 5 gallons (if it's pasty or dried up, add hydraulic fluid and stir!) ... I bought mine from https://www.zoro.com/kingscote-dye-...red-4-oz-506250-r4/i/G5130815/#specifications (I bought some gloves also to bump total up to get "free shipping!")
Wear gloves, I recommend pouring/dripping it into the jug, then pouring into tractor ...
2 drops per gallon ...
same stuff I use
/ Anyone DIY dye their hydro oil? #82
I use the JD dye. It works, turns the oil red. Does not take much. My L3600 has a sight glass, could not see the oil without the dye. Easy, just pour it in. Might mix with some of the oil to pour easier.
I use the JD dye in my 25 year old Kubota. It works great
/ Anyone DIY dye their hydro oil? #84
I need to do this during my next fluid changes, especially on the Kioti.
Did it ever turn red?
I haven't been out in daylight this week to check, and the tractor has only run a few short stints for loading pallets on trucks. This weekend will be spent working on the trailer (gotta paint!) and blowing leaves, so no tractor time, but I'll at least try to check the fluid on the tractor... I'll have to move the tractor to get the mower out, anyway.
/ Anyone DIY dye their hydro oil? #87
Just my guess, but even if you have 10 gallons capacity, not only should you see it, but your pump should totally circulate it in less than 2 minutes ... As that would be 5 gallon a minute ...
/ Anyone DIY dye their hydro oil? #88
I've never had to dye my hyd fluid, but maybe that's because all my equipment have dipsticks instead of sure glasses.
Sent from my SM-S921U using TractorByNet mobile app
/ Anyone DIY dye their hydro oil? #89
I can see my fluid in the glass fine in the daylight, but in my shed at 5am it is like a cave and I only have.... the equivalent of a 60W bulb that does not give me light enough to see the fluid in the glass and my flashlight and drop light both cause too much glare on the glass to see un-dyed fluid. With the red dye I have none of these issues.
/ Anyone DIY dye their hydro oil? #90
I’ve never had an issue with a sight glass if it was properly filled. If the level isn’t within glass it can be hard to know if it’s low or high. The tube glasses are better in that aspect but some sight glasses are only about the size of a quarter. My skid steer sight glass has a ball that floats in the tube that fixes that issue. I also carry a pocket flashlight that I probably use 50 times daily.
Forgot about too low or too high. But there might be other indications that caused one to look. Maybe.
/ Anyone DIY dye their hydro oil? #92
Without reading back 10 pages - Toro sell their red dye in small bottles.
/ Anyone DIY dye their hydro oil? #93
I never saw the need to dye it.
Yep... confirmed, fluid is red. And now that I can actually see it, I can see it's also right on the mininum line. :ROFLMAO:
Will add more tomorrow. Color is very faint, as bottle is spec'd for "up to 5 gal" and my system is more like 8 gal, so I may even pick up another bottle.
Then you're in the wrong thread! :p This isn't for you.
/ Anyone DIY dye their hydro oil? #95
I'd give it a bit more time ... Especially after you wash some more down when you "top it up" ... I know a lot of people that say it's really enough in that tiny jar for 10 gallons ...
Any guess on how much fluid a 320R loader holds, between its 4 cylinders and 80-odd feet of plumbing? :ROFLMAO:
/ Anyone DIY dye their hydro oil? #97
The hydro oil in my 2019 tractor remains so clear and clean, that I almost can't see it on the heavily-hashed dipstick on my 3033r. I see some run hydro oil (probaby ATF) with red dye in it, and I'm wondering, does anyone put some dye in their own hydro oil to make visibility at least a little better?
Done all the time. For the dye to use browse the Web link below.
**SALVAGE ROW STARTS HERE** (A60430)
**SALVAGE ROW...
19126CFL (A59228)
19126CFL (A59228)
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A60430)
UNUSED SDLANCH...
2 ROW AULTIVATOR (A60430)
2 ROW AULTIVATOR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Ford F-250 Pickup Truck (A59230)
2017 Ford F-250...
