Dmacleo
- Joined
- Sep 11, 2020
- Messages
- 1,994
- Location
- Etna, Maine
- Tractor
- 2010 MF GC2400 Owner, 2012 MF1532 User
Yep... confirmed, fluid is red. And now that I can actually see it, I can see it's also right on the mininum line.Just my guess, but even if you have 10 gallons capacity, not only should you see it, but your pump should totally circulate it in less than 2 minutes ... As that would be 5 gallon a minute ...
Then you're in the wrong thread!I never saw the need to dye it.
Any guess on how much fluid a 320R loader holds, between its 4 cylinders and 80-odd feet of plumbing?I'd give it a bit more time ... Especially after you wash some more down when you "top it up" ... I know a lot of people that say it's really enough in that tiny jar for 10 gallons ...
Done all the time. For the dye to use browse the Web link below.The hydro oil in my 2019 tractor remains so clear and clean, that I almost can't see it on the heavily-hashed dipstick on my 3033r. I see some run hydro oil (probaby ATF) with red dye in it, and I'm wondering, does anyone put some dye in their own hydro oil to make visibility at least a little better?
