Anyone DIY dye their hydro oil?
   / Anyone DIY dye their hydro oil? #92
Without reading back 10 pages - Toro sell their red dye in small bottles.
   / Anyone DIY dye their hydro oil? #93
I never saw the need to dye it.
Just my guess, but even if you have 10 gallons capacity, not only should you see it, but your pump should totally circulate it in less than 2 minutes ... As that would be 5 gallon a minute ...
Yep... confirmed, fluid is red. And now that I can actually see it, I can see it's also right on the mininum line. :ROFLMAO:
Will add more tomorrow. Color is very faint, as bottle is spec'd for "up to 5 gal" and my system is more like 8 gal, so I may even pick up another bottle.
Then you're in the wrong thread! :p This isn't for you.
   / Anyone DIY dye their hydro oil? #95
I'd give it a bit more time ... Especially after you wash some more down when you "top it up" ... I know a lot of people that say it's really enough in that tiny jar for 10 gallons ...
Any guess on how much fluid a 320R loader holds, between its 4 cylinders and 80-odd feet of plumbing? :ROFLMAO:
   / Anyone DIY dye their hydro oil? #97
The hydro oil in my 2019 tractor remains so clear and clean, that I almost can't see it on the heavily-hashed dipstick on my 3033r. I see some run hydro oil (probaby ATF) with red dye in it, and I'm wondering, does anyone put some dye in their own hydro oil to make visibility at least a little better?
Done all the time. For the dye to use browse the Web link below.
2018 Lexus IS300 Sedan (A55853)
2018 Lexus IS300...
42013 (A51691)
42013 (A51691)
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A55314)
2006 Heil Tanker...
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
