2665- keeps gaining oil in the crankcase. Any other sources other than Hyd Pump?
   / 2665- keeps gaining oil in the crankcase. Any other sources other than Hyd Pump?
Pump went in yesterday, it's a different tractor now. all better. The Ebay unit is identical to the OEM, no issues whatsoever swapping it out. The pump has a rubber spider that meshes with the drive gear, so 3 hoses, 4 bolts and it's out.
One more thing- There is a grease nipple on the ft cover that holds the bearings for the pump drive. Don't forget to lube the bearings periodically. There is a 4 mm hex plug below the nipple. remove it and pump grease until it comes out the hole for the nipple.
The Ft seal on the pump was soaking wet, as suspected. I also suspect there was leakage between the two pumps, as the power steering improved quite a bit, and lost a lot of the funky noises it used to make while turning the wheel. The old pump looks rebuildable, or at least disassemble-able, hard to tell where to find parts. I'll pull it apart more out of curiosity then anything, maybe see something to better understand the failure mode. If I can manage to rehab it, it would be nice to have a spare, given what things now cost out of India...
   / 2665- keeps gaining oil in the crankcase. Any other sources other than Hyd Pump? #23
Seals and bearings part number are universal should be able to get at any seal and bearing outlet if not at a hydraulic rebuild shop
yeah, it's going to be a winter project to see if I can refresh it.
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
2005 Tennant ATLV 4300 Turf Vacuum (A55851)
2005 Tennant ATLV...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
New/Unused 78in Quick Attach Skid Steer Grapples (A54865)
New/Unused 78in...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
