Making gas cans great again
/ Making gas cans great again #101
Government regulators do not use the products they regulate.
That’s right. I have seen more than 1 Gubmit post emissions diesel pickup with NO DPF or DEF.
They know it’s BS.
/ Making gas cans great again #102
An acquaintance of mine owns a large trucking company in California. He said that when the DPF and DEF became mandated on his trucks, his towing costs (for repairs) at least doubled.
/ Making gas cans great again #103
I think you are in the minority. I don't usually spill with the new cans, but being older and holding up a 5 gallon can that takes way longer to pour than the old vented ones sucks. I'm in good shape now, but I can see a day in the future where I won't be able to. I'm also starting to get pissed off every time I fill something and have to wait so long to finish as the air bubbles into the can. So what do I do? Get smaller cans and spend even more time filling up? I am sure I probably spilled a little with the old cans, but the spring loaded nozzles that fell apart spilled way more than anything else I ever used. I do not have any of those now. I do agree that you need a tight seal for the ethanol to keep from getting water in it longer, but what I remember in the old days had a vent that closed and a cover on the spout that screwed on. Maybe they didn't have those in Canada?
Remember your puck will sink when the ice melts... and I'm just kidding on that one so don't take it wrong. We are hockey fans in Texas and there is no ice here.
I have 2, 5G Eagle safety cans. I used to really like to use them, but at 82 I can no longer squeeze hard enough to keep the vent cap open.
/ Making gas cans great again #104
They know it’s BS.
Yes, many trucks in government service are not subject to the government's regulations for us little folk. But I was referring how government regulators writing regs for gas cans do not use gas cans themselves. Don't mow lawns. But feel their superior intellectual powers, having contemplated the situation, have rightly determined Things Must Change, and so dictate that we obey.
/ Making gas cans great again #105
I think you’ll find the next few years may show some changes in the typical bureaucrat/faculty lounge thinking we have seen for many years.
/ Making gas cans great again #106
These are GREAT cans which we have a few of. For easier pouring, try putting a small screwdriver under the fill cap so as to let air in and you aren't doing it yourself. Seems that would lessen the force to keep them both open while pouring? Another idea is to get a velcro strap made for cords, put in on where you are normally holding the can, while pouring. If installed and tight, this would hold both lids open for you.
/ Making gas cans great again #109
I’ll beat a dead horse a little more. I bought on of those nozzle and vent kits from Amazon and installed them on my diesel cans. With stuff down lower they work well. My tractor fuel tank is about waist level and the fast pouring cans are a problem. Trying to hoist a can up, get the nozzle in the filler and not dump all over is and issue. I got one of those cheap battery pumps and once a couple of gallons is out of a 5 gallon can you can tilt it into the filler and just dump.
/ Making gas cans great again #110
Almost makes me hope that they will get rid of DEF next!!!!
100% - I got rid of all my crappy plastic cans with the EPA restrictive spouts and broke down and paid $$$ for Justrite ( painted galvanized) gas and diesel cans that my kids will inherit. they are safer and pour fantastic, in the long rum they will be cheaper.
/ Making gas cans great again #111
I suppose there are good battery pumps out there but I've had two from Harbor Freight and they both crapped out after a couple of uses. So I'm back to hoisting the can over the gas tank.
/ Making gas cans great again #112
/ Making gas cans great again #113
Had one from harbor freight that lasted 4 years, replaced with one from Amazon that has a nozzle that can be locked on. Going to give it a try, same price as harbor freight.
/ Making gas cans great again #114
/ Making gas cans great again #115
While I've hated almost every safety gas can I've had I do really like my Sur-Cans. I use them for both gas and diesel and I find them really easy to use, they vent when you open the valve and they flow pretty well. They are great especially with my small 2 stroke equipment, very precise flow control and the larger 5 gallon cans I have for diesel sit right on the tank, I bend the spout into the tank and hold the handle, super easy. Pricey but they work.
/ Making gas cans great again #116
I just unscrew the filler neck they give you and pour directly into a funnel I spill less and fill faster
/ Making gas cans great again #118
I use 5 gallon "utility cans" with a big screw on cap. Put one of these through the treads threads in the center. Use the valve to regulate volume of flow or inhibit until the nozzle is in the filler cap.
/ Making gas cans great again #119
I use 5 gallon "utility cans" with a big screw on cap. Put one of these through the treads in the center. Use the valve to regulate volume of flow or inhibit until the nozzle is in the filler cap.
I’ve got one of those racing jugs and I have the elbow for it that puts a bend in it but I hadn’t seen the add on with the valve. Looks like helps.
/ Making gas cans great again #120
My first gas can was galvanized steel and lasted less than a dozen years before I had to replace it due to a leak from rust. I'm guessing that was in the mid 1970's. I'm still using it's plastic replacement along with a dozen others I purchased at a garage sale for $2.00 each. I will admit that only about three of the spouts are still serviceable and it's time to buy some. All of the cans have vents.
2014 Toyota Tacoma Ranch Camper Shell (A64126)
2014 Toyota Tacoma...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
CATERPILLAR 314EL CR EXCAVATOR (A64277)
CATERPILLAR 314EL...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
2016 Ford Transit 350 Wagon Passenger Van (A64556)
2016 Ford Transit...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
