Making gas cans great again
   / Making gas cans great again #111
I suppose there are good battery pumps out there but I've had two from Harbor Freight and they both crapped out after a couple of uses. So I'm back to hoisting the can over the gas tank.
   / Making gas cans great again #112
   / Making gas cans great again #113
Had one from harbor freight that lasted 4 years, replaced with one from Amazon that has a nozzle that can be locked on. Going to give it a try, same price as harbor freight.
   / Making gas cans great again #114
   / Making gas cans great again #115
While I've hated almost every safety gas can I've had I do really like my Sur-Cans. I use them for both gas and diesel and I find them really easy to use, they vent when you open the valve and they flow pretty well. They are great especially with my small 2 stroke equipment, very precise flow control and the larger 5 gallon cans I have for diesel sit right on the tank, I bend the spout into the tank and hold the handle, super easy. Pricey but they work.
   / Making gas cans great again #116
I just unscrew the filler neck they give you and pour directly into a funnel I spill less and fill faster
   / Making gas cans great again #118
I’ll beat a dead horse a little more. I bought on of those nozzle and vent kits from Amazon and installed them on my diesel cans. With stuff down lower they work well. My tractor fuel tank is about waist level and the fast pouring cans are a problem. Trying to hoist a can up, get the nozzle in the filler and not dump all over is and issue. I got one of those cheap battery pumps and once a couple of gallons is out of a 5 gallon can you can tilt it into the filler and just dump.
I use 5 gallon "utility cans" with a big screw on cap. Put one of these through the treads threads in the center. Use the valve to regulate volume of flow or inhibit until the nozzle is in the filler cap.
   / Making gas cans great again #119
I use 5 gallon "utility cans" with a big screw on cap. Put one of these through the treads in the center. Use the valve to regulate volume of flow or inhibit until the nozzle is in the filler cap.
I’ve got one of those racing jugs and I have the elbow for it that puts a bend in it but I hadn’t seen the add on with the valve. Looks like helps.
   / Making gas cans great again #120
100% - I got rid of all my crappy plastic cans with the EPA restrictive spouts and broke down and paid $$$ for Justrite ( painted galvanized) gas and diesel cans that my kids will inherit. they are safer and pour fantastic, in the long rum they will be cheaper.
My first gas can was galvanized steel and lasted less than a dozen years before I had to replace it due to a leak from rust. I'm guessing that was in the mid 1970's. I'm still using it's plastic replacement along with a dozen others I purchased at a garage sale for $2.00 each. I will admit that only about three of the spouts are still serviceable and it's time to buy some. All of the cans have vents.
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2013 Chevrolet Silverado 3500HD 4x4 Crew Cab Flatbed Truck (A55973)
2013 Chevrolet...
Country Line 3 Point 48" Brush Cutter, 540 PTO, Asset# 63 (A59076)
Country Line 3...
2025 TPM-16 Mini Hydraulic Excavator W/Dozer Blade (New/Unused) (A59225)
2025 TPM-16 Mini...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
JOHN DEERE 261 GROOMING MOWER (A52708)
JOHN DEERE 261...
