Making gas cans great again
   / Making gas cans great again #131
"I really disliked lifting the 5 gal of diesel" I agree. Amazing that I can't find 3-gallon Diesel cans even though they make 3-gallon gas cans. My standard operating practice now is to only put 3-1/2 to 4 gallons in each can when I refill.
I wuz gonna say - there is no federal law saying you MUST put 5 gallons in a 5 gal jug... Instant 3 gal jug!😁
   / Making gas cans great again #133
My first gas can was galvanized steel and lasted less than a dozen years before I had to replace it due to a leak from rust. I'm guessing that was in the mid 1970's. I'm still using it's plastic replacement along with a dozen others I purchased at a garage sale for $2.00 each. I will admit that only about three of the spouts are still serviceable and it's time to buy some. All of the cans have vents.
Don't store the gas can on concrete. Wonderful heat sink maximizes condensation in the can.
   / Making gas cans great again #134
I do the same. 3 gallons in the 5 gallon can. Partially for weight, partially so I can tip it over farther before fuel flows out the nozzle.
   / Making gas cans great again #135
Well I only read the first 10 pages of this thread.
Bought my first No Spill Gas Can about 10 years ago but after owning the first one I’m not interested in any other brand, I now own 6 No Spill cans.
   / Making gas cans great again #136
I have a mix of can types, but like the No-Spill cans the best. I have used their 2.5g can for at least 10 years for my 2 cycle fuel, and it just works.
I have (6) bullet proof metal Jerry cans I use for my walk behind mower, and (3) crappy plastic epa cans with spring loaded nozzles that are only used to empty the last 15 gallons of diesel in my large transfer tank before loading it up for filling.
   / Making gas cans great again #137
I never noticed till you pointed it out that it is hard to find smaller diesel cans. I have a couple Wavian NATO 5 gallon metal gas cans. One came mounted on my antique truck when I bought it. I liked it well enough that I bought another to hold gas for my small engines. They are the supplier of military spec cans to NATO. They much more solidly built than the imitation cans. I checked, and they do make a 2.5 gallon diesel can. Not cheap, but Wavian makes some good stuff:
   / Making gas cans great again #138
Thank you!
But do they have the dreaded EPA nozzle?
   / Making gas cans great again #139
I want Jill to serve all my gas can needs!
   / Making gas cans great again #140
In case anyone cares, I have tried the spring-removal method demonstrated in the video I posted, and it really works. My cans flow fast enough to suit me until a better solution comes along, and they aren't leaking the way they did with Amazon and Ebay nozzles.
First, you pull the spring out. It's recyclable steel, so be sure you either put it in your regular trash or toss it in a lake. Then you grab the red thing and twist it out with pliers. Take care to deform and tear the plastic; this doesn't actually make the spout work any better, but it feels good.
I'll be adding red things and the Amazon and Ebay nozzles to my trash, increasing the load of forever trash in the nearest landfill, or maybe I'll incinerate them illegally in one of my burn piles.
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2008 Kenworth T800 Semi Tractor, VIN: 1NKDX4TX68R235070, Day Cab, Cummins ISX-600 Turbo Diesel (A59076)
2008 Kenworth T800...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2011 KENWORTH T370 (A58214)
2011 KENWORTH T370...
1995 Ford 3930 50HP Utility Tractor w/ Land Pride RCD1884 84in. Brush Cutter (A55973)
1995 Ford 3930...
