/ Pilot Control Spring Mod
OK, James, I installed the springs into my friend's Diggit EM15, and we both like the improved feel. Adding more resistance to the the joystick motions is a plus. Worth trying, IMO.
Here are some pix. The install is very easy, but there are issues with how this joystick is made. The inner boot has is too thick to fit in its upper groove, so it was loose. You can see damage where the installer tried to force it in. The outer boot really needs a plate to secure it, and keep the mounting bolts tight. There aren't even washers there.
The spools should be greased, and the inner U-joint needs some thick oil. That was done here (photo).
@dfkrug Awesome download form your GEN2 install on the Diggit EM15...thank you!!! I am seeing what you saw as far as install and boot configurations. My AGT has the main outer boot with plate PLUS an inner boot that pops on/off. My inner boot requires some extra attention where the wire crowds up tight to the lip...but it will slip on eventually. Curious what grease/oil do you like for the install? I ran with Super Lube O-Ring Silicone Grease. I steer people away from petroleum based. Thanks again! Your thorough and objective view of the mod means alot.
/ Pilot Control Spring Mod #22
Yes, my T-17 is not due until mid July so it will be a while before I can test out the spring kit.
Here is another pilot control that needs help: an AGT Industrial KRW232 skidsteer. This joystick is slightly different than the above, with only one boot, and a different way of retaining it.
You can see the rubber lips and the plate that secures the boot, but it was loose. Greasing the spools is a must, IMO, plus keeping dirt out. We will put the GEN1 springs in there.
This skidsteer suffers from the same problem the 1T excavators have: they are so light that they are VERY jerky. This KRW232 is borderline unusable on pavement due to high traction and powerful hydraulics (V-twin gas engine).
It will be interesting to get your comparison feedback after installing the GEN1 into the KRW. I work with a dealer in New York who installs the kits pre-sale into his KRW/TK skid loaders for all the reasons you laid out. The owner likes the difference the kits make. Thanks!
/ Pilot Control Spring Mod #24
The grease we used for the spools is the reddish lithium-based stuff in the grease gun. Silicone grease would be fine, too.
The oil for the U-joint is a thick motor oil in a pump oil can. You need something liquid for that.
Thanks for your positive feedback.
/ Pilot Control Spring Mod #25
I am late to the party. Just read the article. I purchased a Digmaster 200 in Jan. The boom was really sensitive, I didn't like it all. The rest of the controls I could live with. The Wily Coyote idea hit me soon after. I read about cushion valves. I though for awhile a went to my spring box and dug out a couple of springs used to hold the brake shoes to the backing plate. Helped but not quite right size and too weak Went to Ace hardware and bought a smaller diameter spring, and stiffer. Shortest length they had was 1 1\2" I cut them into 3\4 and bent the little pig tail flat and they work great. What is the price of yours? I still might get a set because I am not satisfied with the wrap where I had to cut it.
Thanks for commenting in @John White . Yes - the cut springs do make a difference for many. My custom GEN2 kits are 17-7 stainless steel and are made from a wire size that maximizes resistance (stiffness) while still enabling the valve to reach full stroke without interference from the spring bottoming out early. My kit also has piston protection built-in. Both kits are $29.95 each. GEN1 is 20% "softer".
Excellent video review with install on a QNT30 machine.
/ Pilot Control Spring Mod #28
That is the third different boot retention system I have seen. And probably the best.
But don't forget to grease the spools, and oil the central U-joint.
That QNT30 guy is gonna hook his boom cylinder hoses and have a Bad Day.
@dfkrug Curious if you had any updates on the GEN1 install into the AGT / CFG KRW232 loader.
/ Pilot Control Spring Mod #30
The owner does not use his equipment much. Both of us tried the Diggit after the spring mod, and liked the new feel. Neither of use dug any holes, then and since.
The skidsteer is very hard to operate with precision. It is a bit better now, but it mostly just sits. Impulsive auction purchase.
/ Pilot Control Spring Mod #31
Installed the pilot spring mod to my TT-17. Bit of a guess how to get the boot off and on the left hand joystick I took off the plastic top of control cover (2 side Phillips screws, a 10mm bolt hidden under armrest stem and disconnect wires.) to find out I could simply pop the rubber boot off to get at the control plungers to add springs. Helped though for stretch fitting boot back on the base.
The right hand joystick I just worked the base of the boot off in the arm recess and added springs before working to stretch it back on. Not sure if I got it perfect but I will find out. Tight quarters in this cab unit.
Thanks for this update @MattB4 ! I have noticed that the majority of installs are around 5-15 minutes. Mine (AGT KU18e) was a bit more involved and probably took me 20 minutes or so. Nothing special needed as far as tools go. Looking forward to your thoughts after taking the kit for a spin.
First known AGT GG45u kit (GEN2) shipped to Upstate NY today.
/ Pilot Control Spring Mod #34
A great co. to deal with. If there is a problem, they take care of it, n questions asked.
Working with a customer in Australia...found out the UHI UME15P mini digger, similar to the Rippa R10, has direct-actuated pilot controls. Looks compatible on the outside, but the spring mod kits are not compatible on the inside. Any other brands out there with this type of system?
Working on a new spring design along with a 3D printed insert to further protect the valve plungers.
USE CASE: SANY SY75 - A couple days ago I received feedback from a customer who runs a land clearing / forestry mulching company. He owns a Sany SY75. He and his crew love the mod and that it "smooths everything out". While still an imported machine (I believe), much bigger and more mainstream than the smaller Chinese mini imports.
Are there other name brands that could benefit from this mod?
Working on some cool pilot control spring mod enhancements. A relatively frequent concern I see/hear about from forum threads is that the springs could scratch the pilot valve plungers. For my current GEN2 kit I addressed this by incorporating a custom coiling feature that prevents the cut wire ends from contacting the chrome surface of the plungers. One of my upcoming enhancements is a protective insert that will prevent all metal-on-metal contact in the critical bottom .250" of the plunger.
/ Pilot Control Spring Mod #40
Why not just take apart the spools and replace the original springs with stiffer ones of the same dimensions?
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63118)
2023 Top Air ATV...
Polaris Ranger 4x4 (A61166)
Polaris Ranger 4x4...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
UNUSED MGY-100KW FUEL HEATER (A62131)
UNUSED MGY-100KW...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
