20 inch chainsaw recommendation
/ 20 inch chainsaw recommendation #141
I've never determined the difference between a pro saw and a consumer saw. The only difference I can determine is the price and if the saw is a clamshell design or a full casted crankcase. No matter what brand you buy, the difference between a dog and a racehorse is the loop. A dull loop makes any saw a dog whereas a sharp loop makes it a racehorse. Problem is, most owners who sharpen their own loops, bugger them up thinking they are sharpening them when in reality they aren't. Echo FYI, uses Oregon chain and it's not rinky dink either.
/ 20 inch chainsaw recommendation #142
I'm sure you're not responsible for the really bad reputation Echo's service has.
My own experience was pretty interesting.
Went to Echo's site. Found list of repair centers. Drove to repair center. Repair center said "the guy" who repaired Echos had quit a long time ago. Echo didn't bother updating the site.
Went back to site. Drove to second repair center. They kept the saw for 6 weeks. Told me they couldn't figure out what was wrong with it. They gave it back. No lie.
Went back to site. Drove to third repair center. They kept the saw for 6 weeks. I told them not to sharpen the chain. They gave it back, mostly repaired, with a chain that had its geometry ruined by their amateur grinding. Bought a new chain to avoid spending forever fixing the old one.
The oiler leaked like crazy. I found out the tube had been sliced. Replaced it without bothering the repair center. I could not wait another 6 weeks.
Found out a screw had been left out of the case.
Later on, when I knew more about saws, I realized I could have repaired the saw's original issue myself for $15.
Here's something most people don't know: some repair centers like to hold homeowner saws forever so they can suck up to pros by turning their saws around fast. This may explain why my saw stayed in the shop for so long. A warranty is useless if you're a second-class customer. I really needed my saw during the summer it was in the shop.
The place that sold me the Husqvarna is great. Turns my saws around in 10 days. That includes the Echos. I would never go to an authorized Echo place again. I'd rather pay and have my saw back in a reasonable time.
I can fix nearly any problem with a saw now, so the Husqvarna place will never see me unless something big comes up.
Something to consider: in a time when mechanics charge $100 per hour and up, it's kind of stupid to take a cheap tool like a chainsaw to one unless you have to. I have rebuild kits for all my small engines sitting in my shop, waiting, and I get help from web experts when it's something worse.
/ 20 inch chainsaw recommendation #143
There are definitely differences. Better cases. Bigger carbs without childproofing to make tuning difficult. Electronics. Better chains (Home Depot and Lowe's will not sell you a saw with a real chain). Better coils.
Pro saws are often more suited to hot-rodding, so you can undo the damage the EPA has done.
Some amateur saws are really close to pro saws. The Echo CS-4910 shares a lot of parts with the CS-501P, which is a pro model.
The chain is definitely important. A bad saw with a sharp chain will outperform a good saw with a bad chain.
I learned something interesting. A dull chain will reduce a saw's life. It makes the engine work harder, increasing the heat it generates.
/ 20 inch chainsaw recommendation #144
I thought my CS-590 was a dog until I got the correct information on taking care of it and starting it. I did some damage through ignorance, and I bought an expensive Husqvarna.
When I got the Echo figured out, I was able to turn it into a great saw. I advanced the timing. I opened up the exhaust. I started using Biobor EB instead of Sta-Bil. I tuned it to about 15,000 RPM, properly. I fixed the carb so it doesn't have a hole in the main jet. I got a real chain to replace the Romper Room chains all amateur saws come with.
It's a monster now. Put $500 into one a CS-590 and a few parts, and you can have a really nice saw without going up the food chain. The CS-590 has a metal case, so it's not all that far from a pro saw.
Don't worry about voiding the warranty, because Echo doesn't honor warranties anyway.
You aren’t the first person I heard that from.
/ 20 inch chainsaw recommendation #145
Echo will do anything to get out of warrantying a saw. My dad was able to get the 590 covered under warranty once but they still charge him some sort of fee to do the work or something. That was 10 or so years ago.
/ 20 inch chainsaw recommendation #146
Why I
Why I buy from a local vs. box store.
They will help if I ever needed to use the warranty, or do the work somewhat reasonably.
Dealer makes the difference.
I took my 490 back after break in and they retuned for me at no charge.
I will bring the 620p back to them too when I'm ready, but it's still running fine.
/ 20 inch chainsaw recommendation #147
I learned something interesting. A sharp chain will reduce a saw's life. It makes the engine work harder, increasing the heat it generates.
Hmmmmm on that one right there. SMH :rolleyes:
What I have seen for many years is just the opposite of that. A DULL chain does that.
/ 20 inch chainsaw recommendation #148
Why I
Yup, definitely makes a difference. If I am buying a new saw, it only comes from a local saw shop and not from a box store. I have a really good dealer 2 miles away from home. They only deal in Echo and Stihl though so I use a different dealer for my Huskys and I have bought from them for over 20 years now. The Husky dealer will look up what he paid for it and aways cuts me a price break over what he normally sells for.
/ 20 inch chainsaw recommendation #149
When I buy new saws I dont buy them for no stinking warranty anyways.
I tear into brand new saws no matter the brand to set up and tune the way I want.
No matter the brands either. Husky Echo Stihl and even Makita Dolmar in the day.
I dont even trust the shops to have the right tune and most dont that I start with fresh tune before I will use.
/ 20 inch chainsaw recommendation #150
Totally respect that mindset.
Problem is, only a few of us have your chainsaw repairing/modifying capability.
So a warranty is more important to the typical owner/operator on TBN.
I have only had 1 warranty claim of Stihl and it was a FS131 weed wacker.
/ 20 inch chainsaw recommendation #151
Only a few techs out there I have talked to and even online talked to I trust.
I was at a echo dolmar dealer once and the tech was only one there.
I ask for the updated af cover for my 7900. He point at a echo and said this one. I walked out smh.
I had a stihl tech try and tell me the 261 piston was chromed. I laughed at him. SMH.
I could go on. Dont trust shops unless you know their folks actually know what their doing.
/ 20 inch chainsaw recommendation #152
Yup, warranty means nothing to me and every saw I buy gets modified immediately.
/ 20 inch chainsaw recommendation #153
Speaking of mods:
I like my saws factory because they get the job done, BUT I can never leave well enough alone 😁
If I modify my 261C or 500i, can the mods be reversed cheaply if I don’t like them?
I don’t really want to make my saws louder, and most mods are opening the bark box.
/ 20 inch chainsaw recommendation #154
500i and 261 just do muffler mods IMO. The 500i just a cover like a straight shot. But you will need your hearing protection.
They are fing loud but the gains are there even over a muffler mod. By just putting the cover on and it adjust to it.
/ 20 inch chainsaw recommendation #155
/ 20 inch chainsaw recommendation #156
261 you could just gill it, hole with deflector, or tube pipe in oem muffler.
If you have the newest with M3 you could even run a Egan pipe. M1 M2 wont flow enough to keep up with pipe.
/ 20 inch chainsaw recommendation #157
I guess I’d have to run one to see/hear increase in noise.
/ 20 inch chainsaw recommendation #158
I guess I’d have to run one to see increase in noise.
The SS is freaking loud. But the gains are there.
I was standing timing guys at Sawfest and all of them running them on their stihl's 400 462 500 etc etc.
They will wake the dead.
/ 20 inch chainsaw recommendation #160
I bought a Stihl MS029 from a Stihl dealer back in 1998 or so, never went back to them.. Wasn't because they suck, they happen to be phenomenal, it was because I didn't need to. One, the saw just plain runs, the other is I did all the maintenance and repairs to it myself as a lot of others do. Fun story, when the muffler split open and melted the top of the oil tank mid-cut through a giant red oak, I bought a MS290 case with a blown motor and swapped my engine into that case. Good as new, with the upgrade to flip caps!
2019 P.J. Trailer Trailer, VIN # 4P5F82029K1307542 (A65563)
2019 P.J. Trailer...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
(3) 17.5-25 industrial tires on Deere 14-lug grader rims, Coal Valley, IL (A65640)
(3) 17.5-25...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
