2022 Outlander Max 6x6
/ 2022 Outlander Max 6x6
Let me know if you fellows would like to see the new heat shield. This is the underside of the box.
I'm sending our pods to my buddies shop who's seen here in these dated pics to be detracked and all bearings spun and replaced if any roughness is felt. Its now the end of there 3rd season and they need to be checked..
I'm also updatingor reinforcing the plow since its the off season now. This machine sees 90% of its hours over the winter..
Update! One of my former grooming cohorts now operates a lawn and garden service shop. He took our 3 season old pods apart (3 or 4, can't recall) to check the bearings. He went through all 4 track pods and found 2 bad bearings on one of the rear drive axles and one rear idler axle. The front main bearings felt good and surprisingly and did not find any rough idler wheel bearings on them. He pulled the caps on all 6 main axles to check for water intrusion. The rear main bearings on order. Normal off season maintenance.
/ 2022 Outlander Max 6x6 #410
So would this be an off road vehicle access only property?
/ 2022 Outlander Max 6x6 #413
That thing is worth its weight in gold at your new place!
/ 2022 Outlander Max 6x6 #414
I have to admit, I have been pretty set on buying a Honda 500/520 smaller SxS when the time comes but you have made me potentially question that.
/ 2022 Outlander Max 6x6 #415
Purpose built machine;will take 2 acres to turn though.I will stick with 4 wheels.My Yamaha will about turn in it's own length.
Yes, but it doesn't have a cargo box and less towing capacity in general. Everything in life is a trade off.
/ 2022 Outlander Max 6x6 #418
My Yamaha Viking does have a cargo box.;windshied ,roof and rated to tow 1200lbs.Pulled a 2500lb.tractor uphill with no problem.
I also have a Yamaha Grizzley 4 wheeler that turns on a dime.
Ive used both those machines and own a Kodiak today.
This past week on our beloved Outlander 2022 6x6 winch decided to leave this planet. Not shock, with all the plowing we've done with it. Then on Sunday it was occasionally was making a terrible noise. Found out today its CV front axle was going out.
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
SCAN TO RECEIVE TEXT UPDATES (A64278)
SCAN TO RECEIVE...
MECHANICAL 4R48" FINGER TYPE SETTER (A64278)
MECHANICAL 4R48"...
461802SFL (A64557)
461802SFL (A64557)
HAMM HC50i VIBRATORY ROLLER (A64278)
HAMM HC50i...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
