Robot mowers
/ Robot mowers #1
Fixastuff
Massey
Who has one and what do you think of it?
I was working in a yard and talked the homeowner about their robot mower. It was a 9 acre yard very hilly. This little thing was out cutting non stop would go charge then get back to cutting. Lines and stripes were perfectly straight. Owner says it cuts their yard twice a week during the summer. I was pretty impressed.
I from flatland area and just bought some hilly property and was wondering how to cut it. I think I know now.
/ Robot mowers #2
Pros and cons to these units. It can be a good thing for you if you remove the trouble spots in your land. Then make certain the radio channel has no interference, else the robot could wander off and loose sense to where home base is located.
Be prepared to wash blood off of the robot from time to time too.
/ Robot mowers
lol. Thanks for the input.
/ Robot mowers #4
How do these things know where to go (and not to go)? Do you need to put some sort of "invisible fence" around the perimeter, flower beds, driveway, etc?
9 acre lawn??!?? :eek:
/ Robot mowers
He said for this one you walked the perimeter with a wheel that set the boundary. The trees and obstacles inside boundary it dodged and cut around on its own. The downside to the one he was using was you have to be within 15miles of the selling store as it used a ground station from it. I’m guess there is some kind of subscription but I didn’t think to ask at the time. It was tiny tiny mower compared to a zero turn but the yard looked awesome.
/ Robot mowers
/ Robot mowers #8
There are 2 kinds, wire bound like those used for invisible dog fences, and others that use a GPS (RTK) system (some use lidar), I own 3 robots.
/ Robot mowers #11
I'm intrigued. We just got a robot vacuum and love it.
Anybody have a model they recommend? I would use it around my house and in the fenced backyard where I can't get my tractor around easily. Not a lot of area, a 1/2 acre at most.
/ Robot mowers #14
I like the idea of them but haven't looking into it yet. I just assume they are a lot of money, and I wonder how long they last?
We have gone through quite a few vacuums in the house to deal with dog hair, and they all work great, until they don't. Roomba is by far the best, but they are all plastic, and the plastic parts wear out way too fast.
I can think of a lot of other things that I would enjoy doing more than mowing around my house once a week. Probably my biggest issue is just wondering if the Scag zero turn will start and actually mow!! Eliminating that struggle in my life would be amazing!!!!
/ Robot mowers
Which ones have you used and what is your recommendation? My new yard is 1.5 acres and I don’t want a ground wire.
/ Robot mowers
I was told the one for 9 acres was $12,500. The ones I’m looking at for 1.5 acres are 3-4k. I work outside all day, the last thing I want to do is cut grass after that.
/ Robot mowers
Here is a picture of their yard from up top, you can barely see the bit down in front by a small tree.
/ Robot mowers #19
My question is how well or do they, deal with mole runs, exposed tree roots, lawns that are really marginally better than pasture in some places. I would truly like to have something to keep around the house cut so I could only have the big open areas to contend with.
/ Robot mowers
It would appear the poor little mower got stuck today.
I don’t think this little thing could run over a dog if it tried.
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
Geringhoff Control and Manuals (A63117)
Geringhoff Control...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
GMC 6500 (A63291)
GMC 6500 (A63291)
2018 Ford Focus Sedan (A61574)
2018 Ford Focus...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
