quicksandfarmer
Elite Member
What I'd be curious to see is whether in tall grass it can "nibble" -- take passes at half the width of the cutting deck, the way you would if you were mowing grass that was more than your mower could handle.
You don’t have a clue what you are talking about out. Yes with a zero turn your a hero blasting that tall grass down. With this your grass never even gets tall. It’s a totally different thing. It lays down perfect stripes at what ever angle you select, can also do diamond/checker pattern at what every cross angle you select.Well, it appears with 4" grass, cutting so often, it matted it down significantly with the tracks, and without a high lift deck, the grass that is trampled, isn't cut. Which is what gave the poor appearance. A component of a quality deck is it's ability to lift the grass and cut
